Go Back   Tapeheads Tape, Audio and Music Forums > General Audio Discussions > Receivers, Amps, and Preamps - Solid-State
Receivers, Amps, and Preamps - Solid-State The heart of every system. Discuss your amps, receivers and control amplifiers here.
Old 08-26-2009, 08:53 PM
Socal Sam's Avatar
Socal Sam Socal Sam is offline
Serious AudioHead
Sanyo Plus P55 Power Amp
Check out my Sanyo Plus Series P55 power amp. Despite the small size and BPC styling, it has some serious guts.
Dual mono design
Dual TKK transformers
Two pairs of 63v 10,000uF main filters
Two pairs per channel Hitachi 2SJ49 and 2SK134 Mosfet outputs
Freon cooling tunnel for the Hitachi's
Relay operated speaker selector with one relay each for A and B speakers
With 20,000uF per channel, the 100 wpc rating is conservative.
Old 08-26-2009, 08:55 PM
BroonsBane's Avatar
BroonsBane BroonsBane is offline
raisn em up waxn em down
Nice Sam. I had the matching preamp at one point. Sold it and have regretted it since.
Old 08-26-2009, 11:06 PM
Sweet nudies! Thanks.
Old 08-26-2009, 11:09 PM
Socal Sam's Avatar
Serious AudioHead
I have a complete set with rack ears. The preamp is decent enough. The tuner is special and like the P55 has dual power supplies, one for the analog output and one for the digital tuner. I'll open up my T55 and post a nudie.
Old 08-27-2009, 08:20 AM
Socal Sam's Avatar
Serious AudioHead
I was giving the P55 a good workout last night and I heard a soft gurgling sound coming from the P55. That's the freon circulating inside the tube. It sounds just like an air conditioner unit. No worries, the gurgling is inaudible with music playing.
Old 05-09-2010, 04:48 AM
Patrick Patrick is offline
New To Tapeheads
Sanyo P55 Amplifier
Hello everybody, My name is Patrick and I am from South Africa and I am new to your forum and I have joined in the hope that somebody can help me.
I have a Sanyo Plus system which dates back to 1983 when I purchased it new. The set comprises of the P55 amp, The separate pre amp, the digital tuner and the programmable tape deck.
This unit has run all these years delivering incredibly clean and powerful sound which in my opinion is comparable to the best available even today.
Finally it has given up the ghost, and the local agent tells me that it was discontinued 18 years ago and they can't help me. We do not have competent technitions available for this kind of equipment here and there are no service manuals or schematics available. Please can anybody help with this documentation?
I have opened up the amp as this is where the puff of smoke appeared to emanate from and I found a 1 amp bridge rectifier well and truly cooked. Also several solder joints which have deteriorated over the years. I have replaced the bridge and repaired all the joints. Also I have stripped all the switches and serviced them and confirmed that they are all functioning correctly. The main on/off switch and the speaker switch have been a bit dodgy for years but they are now in good shape again. I have tested both transformers and both function correctly. When I power up the amp, all the leds on the front panel light up and stay lit up and the protector circuit doesn't switch off. Please, if anybody can offer advice or sugestions on the repair of this amp, I would be most grateful as it would break my heart to trash such a superior piece of equipment which I have become very attached to.
Thank you. Sincerely Patrick
Old 05-09-2010, 09:44 AM
Socal Sam's Avatar
Serious AudioHead
Patrick: Great amp. You will want to remove the output transistors and check them. Suspect one or more are open. After replacing them, power up with a dim bulb tester or a variac so you do not blow your new transistors. Sorry I can't be more specific but this should get you started. Good luck!
Old 05-13-2010, 01:00 AM
New To Tapeheads
Sanyo P55 Amplifier
Dear Social Sam
Thank you very much for your reply. Are you refering to the 2SJ and 2SK mosfets or the transistors on the other boards. The mosfets are the only parts that I havn't checked yet. If you ever stumble across a service manual or a schematic for this amp I would really appreciate a copy.
Thanks again for the king assistance, I am very grateful for your inut.
Regards Patrick
Old 05-13-2010, 03:22 AM
Originally Posted by Patrick View Post
Dear Social Sam
Regards Patrick
Please feel free to use the link for Njord Noatun's scans as they are provided to Tapeheads members and if you have paper manuals or brochures that you might be able to provide let him know and he may be able to add them (I think he's backlogged but he will tell you when it's time).
Old 05-13-2010, 07:31 AM
Socal Sam's Avatar
Serious AudioHead
Dear Social Sam
Regards Patrick
Patrick, IIRC the P55 is dual mono. So, if you disconnect the amp modules the relay should click because it no longer detects a short. Then reconnect the left and the right individually and you should be able to identify which channel is blown. This is very simple diagnostics, there is a lot more to amp repair than this.
SANYO 8-track RD 8020A (Power sucking) Dumpster Diver Other Tape 34 05-24-2016 11:46 PM
Sanyo Sanyo CDF-MS11 (CD/MD car stereo) carlosfm Mobile Audio 0 12-03-2013 05:02 PM
Power Wedge 212p Power Conditioner tapedeck Receivers, Amps, and Preamps - Solid-State 0 03-22-2011 08:18 PM
MAXimum TUNArific Power of 1080Watts pure power! Maximillian Receivers, Amps, and Preamps - Solid-State 14 01-13-2011 10:59 PM
Crown Pre, power, switcher, power supply Mark J Complete Systems 10 07-24-2010 05:48 PM
