Old 11-01-2013, 08:24 PM
sixtiestaper sixtiestaper is offline
WHAT IS THE BEST TAPE TO USE WITH REVOX?
I have a problem. I own Revox A77's and B77's. The bias and original setting on the boards have never been adjusted,....do not have the proper equipment. I only use Maxell UD 35-180 with them as I had terrible sticky shed problems with all the other older other brand tapes. Is this Maxell tape giving me the best sound from my standard biased A77 and B77? I also own a bunch of Scotch 203 tapes on 7"reels. Will they sound better (haven't tried then yet)then Maxell low noise high output tapes like the UD 35-180 on the above machines with original settings? I can't be the only one with this Revox problem. Also any comments to my question about the brightly colored NAB extensions for Revox NAB adapters from overseas(biggest seller of these on the Bay, for sure) would be helpful, posted below but with no replies. Where has everyone else bought these things?
Old 11-01-2013, 08:51 PM
BradH's Avatar
BradH BradH is offline
Interestingly I have the same ReVox decks you have. A77mkIV and B77. The Maxell UD 35-180 does an admirable job with both. I have a lot of BASF LP35 and LP35LH and it also does decent on the ReVoxes but since they are only 7" reels I usually use my TEAC to record on them since it is set up for these tapes. I can't help you with the ReVox horns as I have no use for them as I don't do any editing that would require them. I also don't really care for the looks of them so I never really researched them. I'm not a blingy kind of guy.
RTR: ReVox B77 & A77mkIV, Akai GX-370D, TEAC A-1230 | CASSETTE: TASCAM 122mkII, Nakamichi CR-3A, Carver TD-1700 | TURNTABLES: ReVox B795, Denon DP45-F | PREAMP: Carver C-5(modded) | TUNER: Sangean HDT-1X | POWER AMP: Emotiva XPA-2 G2 | CD: Pioneer PD-F27 ELITE Jukebox | SPEAKERS: Carver Amazing Line Source, Phasetech Power 10 sub | EQ: Soundcraftsmen RP2215-R | HEADPHONE AMP:Schiit Valhalla | HEADPHONES:Sennheiser HD650, Beyerdynamic DT770-pro-250ohm | DAC:Schiit Modi2
Old 11-02-2013, 03:42 AM
bob955i bob955i is offline
At a pinch, if you compare the source signal to the off-tape one and it sounds pretty much identical with your Maxell tape, then I'd be inclined to leave bias and rec sensitivity well alone, especially since you don't have test gear or tapes to set it back up.
That said, I'm not sure what reference tape Studer ReVox used for alignment but I'd be inclined to think that it would have been very likely BASF stock.
Old 11-02-2013, 04:06 AM
bobreel bobreel is offline
Best tape for Revox
My Revox B77 has been setup for Ampex
456. I am using new RMGI LPR35, SM468 and 911 tapes. Each of these give very acceptable results. I record from FM radio and vinyl, mainly rock and blues.
The only Ampex tape I have, is of unknown origin with SS problems. Maxell tapes work, but the RMGI tapes work even better. Cheers.
Revox tape, Revox owners will find this interesting.... revoxg36 Open Reel Tape Media 5 06-10-2015 06:57 AM
Best tape for Revox A77HS? Lorenzop Reel To Reel 3 08-29-2014 03:21 AM
Tape calibration - Revox A77 Oceansmoving Reel To Reel 128 10-27-2013 11:55 AM
Revox B77 Tape Recommendation 010110111 Reel To Reel 11 09-03-2013 05:35 PM
What is the best tape to use with a Revox B77 DALEK SUPREME DL Reel To Reel 10 06-26-2009 07:34 PM
