Old 03-01-2013, 11:11 AM
toddbailey's Avatar
toddbailey toddbailey is offline
Dr. PC
Interesting Discovery on Exchanging Otari/Teac reel tables
Last night being total bored and nothing better to do I crawled around Utube videos and came across some videos of Otari mx-5050 being demo'd.
One caught my attention where they had 7 inch reels mounted but the typical Nab 10.5 inch hub adapters or rubber reel locks were missing. Upon closer inspection, some one replaced the stock oem reel table with a teac reel table that has the twist and lock mechcanism. This replaces the solid shaft style that Otari used in it's BII series.
With phillips driver in hand I had to investigate if I might have a possible use for my spare set of reel tables. A quick visual indicates they are nearly the same,
After a few minutes of searching for the correct allen wrenches, I was able to replace the Otari reel table with the Teac one, and no modifications are needed.
I was amazed that the motor shaft was a fit as was the teac part being a direct bolt on fit on the Otari deck.
How nice, now I can play a 7 inch reel with out using the funky rubber stopper reel locks or the 10.5" hub locks. Mine are old and worn and provide a sloppy mounting. And very noisy on fast wind/rewind
Now I just need another set of Teac/Tascam TZ-612 adapters. 29ea plus shipping via Teac parts.
Old 03-01-2013, 04:41 PM
Listens2tubes's Avatar
Listens2tubes Listens2tubes is offline
Supporter of Reel Analog-resistance is futile!
Thanks Todd I have been watching Pioneer 1020 reel tables, on ebay, thinking the same thing. They also look like possible replacements. Which Teac tables work?
(3) Otari MX-5050Bll-2 - main deck with MTR metal "smoothie" heads, Ampex A-122 & F-44, Teac A-4010S & A-4070, A-6010 GLS, Revox A77 Mk II, Heath A-16 (Magnecord 1020) __
Old 03-01-2013, 11:35 PM
MrRom92 MrRom92 is offline
I am VERY interested in finding out which teac tables work, as I've been looking to do this mod for years. I HATE HATE HATE the reel tables on my Otari mx-5050 bII and I hate using those stupid adapters. I do like that the reel tables are sturdier than the tascam's, but honestly those are sturdy enough.
It's most probable that you saw a video of an mx-5050 bIII, as that model replaced the stupid reel tables used on the bII with the smart twist-lock reel tables. However, kudos to you for thinking they were modded with teac reel tables and then deciding to try it yourself, hahah.
Old 03-02-2013, 01:32 AM
toddbailey's Avatar
Dr. PC
I forget exactly what model these are off, but I think one of the a-33xx series, maybe a 3340 or 3300.
here a few pictures showing the Otari next to the Teac,
As you can see the shaft hub mounting is the same in height, the reel flange is only slightly larger in diameter and also a bit thicker, but can be compensated for.
I even toyed with the idea of using my x10 reel tables inplace of the 33xx plate just so you can avoid having a teac brand on a Otari deck.
The x10 tables don't have the Teac brand printed on the rubber face, unlike the 3300 series I have.
However the x10 motor hub part won't fit being too tall. But remove 3 screws and the 2 parts separate.
So I'd have to do a bit more parts swapping.
Old 03-03-2013, 10:33 AM
If there is a replacement that could be used as a drop in, no fiddling around needed, I would spend untold amounts to have this done to my deck haha
Old 03-04-2013, 12:47 AM
toddbailey's Avatar
Dr. PC
I purchased a set of teac reel tables off ebay a-3300 series, about a year ago, with the idea that I'd update either by A6010 or my A7010 teac decks. Unfortuantely these 2 decks presented some engineering challanges I wasn't able to address. The U tube video gave these parts a new possibility for use.
Examine the new photos of my Otari MX-5050BII
Installation was fairly simple, and was I was able to R & R with out removing any access covers. All that was required was to remove the 3 phillips screws from the otari reel table then loosen the 2 allen head screws that hold the reel table hub in place. Next remove the table from the hub of the teac reel tables and slide into place. Align the 2 set screws to mate with the 2 flat spots on the motor shaft, tighten slightly and pull forward until the set screws hit the end of the flats on the motor shafts, tighten then replace reel tables.
Thats all I did, and it took all of 30 minutes... The reel table heights came in perfectly centered.
Old 03-04-2013, 09:29 AM
If its that simple I'm definitely looking out on eBay for these things. I'll specifically look for reel tables from the 33 series, unless there are any others that would also work. Thanks!
Old 03-04-2013, 08:24 PM
Now we will be racing to find Teac tables. I'm going buy-it-now, no more getting bid up by my fellow tapeheads.
Old 03-05-2013, 01:26 AM
toddbailey's Avatar
Dr. PC
Just make sure, the hubs are identical to the ones shown in the photos, the x series table hubs are too tall.
Old 06-02-2014, 07:12 PM
kevman kevman is offline
Sorry to dig up an old post but I am about to do this modification and was worried about one thing. What is the likelihood of screwing up the alignment? Are the motor shafts on the otari notched with a flat spot ? How would two set screws work if that we're the case?
Old 03-25-2015, 03:46 PM
thegrayman thegrayman is offline
I would be happy to buy your OTARI hubs and tables. The twist lock is nice but I can do without. EBers charge a fortune for these parts even when you can find them. I am looking for a pair of TEAC tables now. The hubs are usable but the tables are trash. Both spindles broke off. reeltoreelguy@gmail.com.
Old 03-25-2015, 03:53 PM
Almost any table for TEAC TASCAM from a NAB sizes deck will work. The rubber platter design differs but as long as the raised rim is present on the underside you can use them. It is this rim that centers the table on the hub, regardless of the height, X series, or other design differences, steel versus aluminum ect. They ar all intergangable. I did not know that OTARI uses the same dimensions.
Old 03-25-2015, 06:44 PM
gustavoa gustavoa is offline
Teac Tables
They worked for me.
Old 03-26-2015, 01:46 AM
Originally Posted by gustavoa View Post
They worked for me.
_____THAT DECK IS JUST TOO DAMN BEAUTIFUL______
Old 08-10-2015, 11:04 AM
Gerryherft Gerryherft is offline
Nice deck. Where did you get the nice side panels. I also have a Teac A3440s that I have no use for. I might change those reel tables over for my Otari MX505O B2HD. I am also on the lookout for the feet for my Otari if anyone has some spares or can suggest where I can get some. Thanks
Old 08-10-2015, 11:30 AM
johns82's Avatar
johns82 johns82 is offline
Looks like Gustavoa had something to do with it. He makes Otari look like a home unit. hey look it is his deck!
Old 08-17-2015, 09:19 PM
Gatorman082's Avatar
Gatorman082 Gatorman082 is offline
Happiness Is A Warm Head
The X-1000R hubs did not work. The diameter of the piece which slides over the motor shaft is a little too small. Must have switched reel motors at some point. Will try another series tomorrow. I too would love to get rid of those funky OTARI hub adapters. Thanks for the idea, it's a good one.
Otari MTR12, MX5050 BII 2; Sansui SD-7000; Sony TC-755A; Teac X2000R, X1000R, X10R, A3440, A2300SD
Marantz 2252B, 2230; Sansui 4000, 5000A; Sony STR-5800SD; Advent Powered Loudspeakers, Advent 4002, Advent 3002; Presonus Sceptre S6, Sansui SR-929
Old 06-11-2017, 06:15 PM
knownothin knownothin is offline
Are there any Tapehead members that sell the Teac reel tables to make this modification on an Otari BII?
I have the original hubs, but they are not as convenient as the Teac TZ-612.
Old 06-11-2017, 06:57 PM
In fact the tables from the X-1000R, 2000R and all xxR will work but you have to modify the Otari assembly. I cut off the original Otari spindle with a saw-blade then make a centered hole roughly the width of the spindle remains so the TEAC spindle screws all the way down. Then just screw the TEAC table and the Otari assembly together using three M4 screws for each table. Works perfect.
The tables are always for sale on the bay.
Old 06-11-2017, 07:16 PM
This is good info that I am sure many Technician know of already.
The TZ612 units may work but the NAB Shop adapters are going to be much better as those who buy them find out. Plus they do not break when you drop them and when they get old.
Teac X-10R fly-wheels and reel tables knownothin Reel To Reel 4 11-19-2015 07:02 AM
Are not both Teac A3300 reel tables identical? 62vauxhall Reel To Reel 3 06-14-2014 06:07 PM
An Interesting Discovery..... Lance Lawson Reel To Reel 2 01-12-2011 07:44 PM
