Old 01-02-2013, 10:52 AM
Billazehner Billazehner is offline
Billazehner
TEAC X2000R
I recently purchased a TEAC X2000R in the Portland Oregon area with the intention of transferring all of my old vinyl albums to R2R tape. I had previously purchased a X1000R on Ebay that was poorly packed and the USPS delivered it severly damaged. (I am awaiting payment by their insurers but you know how fast the Postal Service works.) My X2000R works great with the exception of the tape counter not counting up or down. I discovered the optical sensor was not emitting it's red light, and swapped the X1000R one that was working. This didn't solve the problem. I took it to my local tech, and he said this was way beyond his comfort level,(I appreciate his honesty). Any ideas of where/who can remedy this would most helpful.
Old 01-02-2013, 11:19 AM
Bandwidth's Avatar
Bandwidth Bandwidth is offline
RTR FREAK & TH SUPPORTER
Not to overstate the obvious - did you check the counter belt?
RTR: SWEET 24
CASS: 1/2 DZ
Old 01-02-2013, 04:22 PM
shotwell's Avatar
shotwell shotwell is offline
Rockin' The Suburbs
There is no counter belt in an X-2000R.
Welcome to Tapeheads Billazehner! Thanks for taking my advice to join.
Tapes from Super Ferric score now listed in classifieds
Pioneer RT-707, Nakamichi ZX-7 & CR7, Technics SL-220 / Shure V15
McIntosh MC-30, Nakamichi CA5, Klipsch Epic CF-3 speakers
Old 01-02-2013, 04:41 PM
Hello Billazehner,
I have not had any of these fail in the years I have been working on them but if it were to have a problem, I am sure DigiKey or Mouser would have an appropriate opto interrupter to sub in. The first thing I would do is make sure the tape thread is correct- it goes over the tachometer roller. Then make sure it is spinning- if the bearing is dry and no spin, no count. Then make sure the DC voltage is getting to the device- you could very well have a connector off somewhere. Then after voltage is there, make sure with a scope that the receptor is not generating pulses. You may search for a new part but it might be that you do not need one. It is like those people that go to far lengths to find solenoid to replace and find out that after all that aggravation that did not fix the problem. Also trace the wires to a connector that might have broken solder joints on the board. With more people getting into these things that are not professionals, the little things can get by them. let me know what you find after all these ideas. The Opto in some units might be infrared and you will not see a light- I don't recall seeing them either but the pulses come off the output pin.
Just one more stupid thing- see if a small cut piece of tape did not get into the Opto Interrupter and block the receptor.
Old 01-02-2013, 06:49 PM
if that opto sensor is IR, take your cellphone and put it in camera mode. point it at sensor up close, you will see the IR led show up as a bright purpleish light on a cell phone camera.
Old 01-02-2013, 06:55 PM
Billazehner
X2000R
Thanks for the suggestions. The tape thread is ok and the roller is spinning. All of the pins connecting the sensor and counter assembly are straight and sliding into their respective slots. I'm not technically savvy enough to make the next step in checking circuits.
Having read opinions of comparisons between the X2000R and X1000R I'm wondering if I should have my X1000R repaired, as only the Reel table assembly on the left side was broken off? Then sell my X2000R, as is to cut my losses?
I talked to TASCAM in Calif. and they wanted a flat $250 in labor + parts and shipping to fix. Feeling kind of dizzy with all of the possibilities. BZ
Old 01-02-2013, 11:06 PM
Bandwidth's Avatar
Would have been easier if it DID have a counter belt! Sometimes simple is good!! I've yet to have the cover off mine (touch wood)!
RTR: SWEET 24
CASS: 1/2 DZ
Old 01-03-2013, 02:19 PM
Jonny Ramone's Avatar
Jonny Ramone Jonny Ramone is offline
Jammis Archivivist
You should be able to use your reel table from the 2000 on your 1000. You might be able to order one from TEAC, or get a used one on Ebay. I think the X7/X700 and X10 use the same reel assembly.
Old 01-04-2013, 12:01 PM
Billazehner
Biting the bullet
After much discussion/frustration, I've decided to send my X2000R to the repair center in Montebello Ca. If anyone has had an experience with them let me know.
Old 01-04-2013, 12:09 PM
Des-Lab Des-Lab is offline
5/12/2008 - 12/27/2014
Be careful with the clowns at Montebello. I've been there (in person) many times, and the last few times I went, I learned you have to spell everything out to the letter with them. Don't just tell them "to fix it", you almost have to lay out step by step directions on how to do it starting with "unscrew the frame...."
Don't assume anything with them. Anything and everything you want done, you need to spell out ahead of time. They are pretty good at following instructions....with the catch being...the instructions you give them have to be almost absurdly long and comically detailed.
Old 01-04-2013, 12:24 PM
Billazehner
I have come to the conclusion that sending it in is my only option as noone here in the Portland Or. area is willing/able to fix my counter problem. I posted on Craigslist for help and got responses that were not worth pursuing. Any other ideas would appreciated. I tried the DIY route and felt like I was getting in over my head. BZ
Old 01-04-2013, 12:26 PM
BlazeES's Avatar
BlazeES BlazeES is offline
on factory service!
It's Tascam for crying out loud...
You may wish to contact Sam (Skywavebe) who knows Teacs inside out, upside down, and in his sleep.
If you haven't shipped it already, give him a shot. He may cost a little more but unlike the drones at Teac, he actually has a brain and you *will* get your job done right without you having to give him the step by step instructions.
Old 01-04-2013, 12:39 PM
captaingamez captaingamez is offline
seconded, keep the money with small business and the tape community.
Old 01-04-2013, 02:10 PM
oldaudioscho's Avatar
oldaudioscho oldaudioscho is online now
Just like Des, Sam is your go-to guy. He just recently did some repair work on my deck. Came back like new. AND HE KNOWS HOW TO PACK AND SHIP FOR SAFE ARRIVAL. Contact him, it won't cost you anything to talk to him.
Sony R2R, TC-558, 580(x2) 755(x2), 756, 758(x2), 765, 766-2
Sony Cassette, TC-K7II, K96R
Sony CD Player, C15ESD, C801ES, C90ES(x2), C69ES(x2)
Sony Receivers, GX9ES, GX10ES
Old 01-04-2013, 10:19 PM
Bandwidth's Avatar
Big plus for Sam - he has expert knowledge on Teac/Tascam, and has a great track record - he is also a selfless tapehead and gives much great advice to the membership (myself included) on this site! A big
RTR: SWEET 24
CASS: 1/2 DZ
Old 01-06-2013, 11:52 PM
Hi Bill,
I was wondering that through my contacting you through Thumbtack and other methods, did you find the answer to your problem or it is still a issue to be dealt with. I am still here to help regardless of if you will send it to me or someone else. There used to be a guy in Oregon called Eugene Audio and the guy's name was Chris. I think he shut down his shop but then made a recommendation to this place below- just an Idea, I have no track record on them but at least they are over there.
Inner Sound
1416 SE Morrison Street
Portland, Oregon 97214
503-238-1955
www.inner-sound.com
Teac X2000R AGAIN Skywavebe Reel To Reel 35 05-29-2013 11:41 AM
Bias Set on Teac X2000R ozoneeater Reel To Reel 5 10-19-2012 06:49 PM
Teac X2000R tensioners theoman Reel To Reel 60 08-06-2011 10:40 PM
Teac X2000R nmharleyrider Reel To Reel 0 09-21-2010 07:40 PM
