Old 11-03-2012, 09:06 AM
ppeterso2's Avatar
ppeterso2 ppeterso2 is offline
Fostex Model 20 Question Reel to reel
Hello all,
I have a Fostex Model 20 portable, high speed 2T reel to reel that I really like because it sounds great, it's lighter than my Revox PR99mkII and it still has a lot of on board features (including the cue track for my SMPTE)
However, I have one concern: Fostex placed a stupid little beauty tab that is part of the head cover that covers the capstan (see attached picture) that the capstan is rubbing against during vertical operation--irritating and it can't be good for wow and flutter... I've tried to bend this tab and it got better, but still rubs. I notice some Fostex M20's, M80's and A2's have this piece and others don't--plus the E2 doesn't have it either. I am a few seconds away from cutting it off with a dremel (or a razor blade if that works) but wanted to make sure I'm not missing something here: The capstan has a little vertical play, but it doesn't seem to be more than other decks I have--any problems noted with capstan flywheel tolerances on a Fostex?
Is there a way to adjust the flywheel/capstan assembly (I didn't want to tear the front panel down if that would be pointless)?
Old 11-03-2012, 09:36 AM
jan_stevns's Avatar
jan_stevns jan_stevns is online now
Tapedecks & Bernese mountain dogs ..that's life
Originally Posted by ppeterso2 View Post
..... I am a few seconds away from cutting it off with a dremel (or a razor blade if that works) but wanted to make sure I'm not missing something here: .....
You're missing one thing - It is there for a reason To eliminate horisontal play in the capstan.
A few vendors figured out another was to eliminate this problem, like TEAC with their X series where some has a magnetic solution to the problem.
Old 11-03-2012, 09:41 AM
ppeterso2's Avatar
Great point, LOL!! that's why I posted. Thanks!--I figured I was missing something!! Do you think I should grease it or something to eliminate the scraping?
I remember my RT909 pioneer deck has some plastic ball bearings for a similar reason!
#asktwicecutonceifyoucutatall
Old 11-03-2012, 10:22 AM
jan_stevns's Avatar
my grandfather used to say : Meassure twice, cut once
Every time i've seen those things they has been grease a tiny bit with something. But i honestly can't remmeber any manual adressing this issue.
Old 11-03-2012, 10:31 AM
ppeterso2's Avatar
Sometimes the simpliest things...
I put a small dab of some nickle metal anti-seize on it and that did the trick! It is extremely quiet even with the head cover tightened all the way down.
Thanks!
New here to forum reel to reel webcor model Model no. Lp2712-1 MrRoberts Reel To Reel 2 10-29-2015 12:30 PM
Teac Reel to Reel Model A-6010 lrbmaz1 Reel To Reel 9 07-11-2015 06:58 AM
Reel to Reel unbalanced I/O question / word of warning aswefallintostatic Reel To Reel 0 04-26-2015 08:53 AM
What model/brand of reel to reel in this movie cad55ken Reel To Reel 4 06-12-2014 11:05 PM
PHILIPS REEL TO REEL TAPE RECORDER MODEL N4506/15 scotchtape Reel To Reel 3 04-06-2011 04:41 PM
