Old 08-05-2011, 03:34 AM
allthingsanalogue's Avatar
allthingsanalogue allthingsanalogue is offline
Denon DRM-700, any good
Is the Denon DRM-700 a decent deck?
Old 08-05-2011, 04:26 AM
A.N.T.'s Avatar
A.N.T. A.N.T. is offline
Not without some modifications, same goes for DRM-800 - these two share almost exactly the same circuit but different mechanisms and heads, single capstan and permalloy heads for DRM-700, dual capstan and amorphous heads for DRM-800.
Main problems are - a very strong interference from the fluorescent display and flat cable that connects it to the main board (needs some proper screening, I've used copper foil to do it), clipping on the REC MUTE transistors on the input of the recording amplifier (as a result the deck distorts at near 0 dB when records, even if the tape allows for much higher levels) and JFET output mute switches that add a lot of distortion on the output.
On top of these big problems there are also 4066 CMOS switches for the monitor switch in both decks and (very nasty) a 4066 switch in the DRM-800 for two inputs (in the DRM-700 it is absent as it has only one input and no switching).
After fixing these problems it could be a decent deck.
Alex
Old 08-05-2011, 04:28 AM
thanks, i'll give it a miss!
Old 08-05-2011, 05:25 AM
CottonSwab CottonSwab is offline
Alex
Alex,
That's a nice tip on the display harness I am going to check out my DR-M24 and 44 HX units and see whats up there. -Thank You
Those 4066 CMOS gates are extremely prone to static failure. Always were.
Ron
Old 08-05-2011, 05:27 AM
I don't think the "Calibration" record level can be set for either of these. I have looked at them too. Otherwise they seem nice save for what Alex recommends...
Ron
Last edited by CottonSwab; 08-05-2011 at 08:58 AM. Reason: To clarify Calibration Record Level
Old 08-05-2011, 07:11 AM
of course, i guess you meant the "calibration record level"... that is missing on many decks... because saying simply "record level" we may do a bit of confusion with the "input record level" that is present on any standalone decks.
CHEERS,
Vince.
Old 02-08-2016, 02:10 PM
ChopperCharles ChopperCharles is offline
Don't forget that the capstan is mounted with plastic parts, not metal. They're under a lot of tension via the pinch roller, and they break... leaving you with massive tape skew and a pretty much useless deck. I yanked the heads and binned the rest.
Charles.
Old 02-08-2016, 04:11 PM
Wojszwillo Wojszwillo is offline
For Denon's go for Denon DR-M33HX (manual bias tune) or Denon DR-M44HX (auto calibration of level and equalization).
Transports for these are almost the same for both (44 - direct drive, 33 belt driven; other - the same) and electronics are almost the same, except auto calibration board of DR-M44HX.
Both have the same perfect Alps heads.
Very nice sound.
When transport calibrated / greased etc. properly, you can have such W&F as of my 44.
Jamo E850 PDD, Jamo E8SUR.2; Technics SL-Q2, audio-technica AT150MLX, audio-technica MG-10; Denon DR-M44HX; Denon DVD-A1XVA, Denon DVD-3930, Denon DVD-2930; Denon AVC-A11XVA, Denon AVR-3806; Panasonic NV-HD687
Old 02-08-2016, 07:51 PM
One question though, does the DRM-700 have the good ALPS heads?
Charles.
Old 12-29-2016, 10:08 AM
FinnL FinnL is offline
Hi Charles,
Would you be willing to part with the Rec/PB head assembly you pulled?
I have a Denon DR-M3 not used for decades. When I turned it on recently got no sound on playback. Turns out the playback head is dead (infinite ohms on both Left and Right). Not worn from usage. I guess temperature changes over the years caused a disconnect internally. So I'm looking for a replacement. Part# 3918076000 is no longer available, nor is substitute 391807610. But the DRM700 is listed as a compatible model for those heads.
Finn
Old 01-02-2017, 03:06 PM
I'll see if I still have the heads in my parts bin.
Charles.
good machine, good tape, & a good tapist ke4mcl Cassette 3 03-30-2015 05:24 PM
Denon and Denon works active Cassette 7 05-28-2014 12:34 PM
Denon DN-790R good? tallman5353 Cassette 3 08-16-2013 07:58 AM
How good is the Denon DN-780R? Orbitron Cassette 0 10-28-2010 06:09 PM
Denon HD 8 100 good? dannyboy131973 Cassette Tape Media 6 12-18-2009 11:13 AM
