My Onkyo TA-630 is up and running!!
Anybody got a user manual for this deck?I need to figure out the Accu-Bias feature on this deck.I replaced the belts and it sound really nice,possibly the best of my 2-header!! Thanks for the help and info....Rob
I have one of these - it is a pretty good deck. The only issue I have had with it is that the record interlock occasionally snagged and I couldn't depress the recording button. After a round of fiddling, I determined that it was the metal strips in the door well that press the cassette to the rear of the well - these had gotten slack with the years and the cassette top was not fully depressing the pin up at the top as a result. Gentle finger pressure bends those strips back into position - now mine is working fine again. Ah, those mechanical issues...
I am not sure how the accu-bias works on this one. It makes good recordings regardless... Happy Onkyo-ing!
Tape decks: Nakamichi BX-100 silver, Onkyo TA-630D, Onkyo TD-301, HK 212, Nakamichi Cassette Deck 2, Technics RS-B18, JVC TD-R411. Receivers: HK-590i, HK 330B, HK 430C, B&O Beomaster 4000, Vector Research VX-3500A, Onkyo TX-8511, Yamaha CR-420, newer Yamaha 5.1 also. Speakers include Polk, Infinity, KEF, KLH, Paradigm and Advent. Turntables:Yamaha belt-drives, Kenwood direct-drive. CD players include NAD, Sony, Denon and Onkyo. |
Please,please,please,please Nando!!! That would be great!! Rob
Nando. |
PS -- Great looking vintage piece Rob!
Moderator; Sony cassette spoken here... Retired USN Pain heals. Chicks dig scars. Glory ...... lasts forever.... |
Nando. |
Sent! Thanks!
Thanks Nando!!!
Hey Nando!! Yes,your email with the SM for this deck was great,did what was said,made a beauty of a cassette for my 1st with this deck...man this deck sure sounds great.Another plus is that the tapes sound great on my other decks,so it's definately a keeper.Will be making other tapes soon,plan to use this deck in the main system for quite awhile.It's just nice to optimize the type of tape with the tapes I have,I'm sure I have other decks that can do it and outperform this Onkyo,but this deck sounds that good!! Rob
Nando,
I just started this...sounds like you're 1 person I can ask...maybe there are others that also can help... Took my Onkyo TA-630D to the shop due to a drive problem discovered after many months of non-use...the serviceman advised that the Belt(s) "Melted into the Motor" and would be impossible/too costly to fix in lieu that a new motor is also no longer available...I still play my great Denon (fecr) and cro2 tapes from the 70s/80s but I may now be without service options and a home tape player...(the service shop Did old Sanyo RD 5250 and Technics RS-TR232 recorders to purchase at under $100...)... any advice is welcome...I really liked the Onkyo and would be nice to find another motor... tks. Buckeye |
The belt or belts,"look" like they melted to the motor,or onto the pulley,but it should have not ruined the motor.What really happens is the belts turn into this sticky goo when they finally "decompose" with age,and you can get in there with some q-tips and alcohol and clean the mess up,and then find out what size belt(s) you need and get the deck up and running.It is a pain cleaning and removing the belt goo,but your motor should be ok,not "burned out". You'll need to check with someone else here on the forum about belt sizes,since your original belt is no longer viable to get a size reference.Replace the belts,clean the tape path and see how the deck sounds!! Rob
Even if the motor were bad, new ones are definitely available (not the exact motor, but a good sub). |
| PIONEER PL-12D-II RUNNING FAST. ? | westgate | Turntables And Vinyl | 8 | 10-16-2010 06:37 PM |
| DN-790r running fast | jwrosenthal | Denon | 1 | 03-20-2010 11:36 AM |
| What DAC Are You Running? | Socal Sam | Compact Disc | 12 | 07-14-2009 07:49 AM |
| dbx 224x Up and Running | Acoustic | Enhancements And Accessories | 29 | 09-22-2008 10:25 PM |
| Bike Not Running Yet | Rat44 | Other General Interest | 13 | 08-01-2008 04:22 PM |
