Old 01-11-2017, 07:39 AM
yuriy yuriy is offline
Pioneer CT-S620 "overload" in play mode.
Pioneer CT-S620 "overload" in play mode https://youtu.be/HtGLuYzBroo
Old 01-11-2017, 08:43 AM
lucky lucky is offline
Calibrate the deck with the internal playback level pots. Usual 200nW at 0dB or Dolby mark.
www.luckyx02.de
Old 01-11-2017, 09:29 AM
It is not calibration problem, it happens time to time, only after switch on and only with normal tape.
I think the problem is in Dolby
Old 01-11-2017, 09:40 AM
Just explain it exactly, which state Dolby ON/OFF C or B. If its happened only with FE tape its possibly the sensor leaf contacts dirty. How many tapes has you cheked ?
www.luckyx02.de
Old 01-11-2017, 10:24 AM
It happens not every time. Only after long off.
If dolby switch on, no matter B, C - indication is correct.
All switch is OK, and all mechanical manipulation of it due to play mode don"t
leads to "overload"
It is a short period of malfunction every time.
Old 01-11-2017, 10:30 AM
Possibly a cold soldering point at the cmos (mute) switches or itself is defect. Did you have a circuit diagram ?
www.luckyx02.de
Old 01-12-2017, 01:31 AM
I prefer to find a particular point where playback equalization may vary.
These points I checked:
when this happens in the output signal just a lot of high frequencies , everything else was fine
Old 01-12-2017, 01:48 AM
Here you see the NR switches, usually a cmos 4066. IC 151, 251, 351. They are suspect in my eyes !
www.luckyx02.de
Old 01-12-2017, 02:24 AM
Old 01-12-2017, 02:44 AM
Ah ja...Did you have a scope for tracing back the signal ?
www.luckyx02.de
Old 01-12-2017, 02:45 AM
SR2245's Avatar
SR2245 SR2245 is online now
There are no IC 151 and 351 inside the CT-S 620.
These switches are CT-S 820S parts only.
Old 01-12-2017, 02:49 AM
The fault is very short and occurs infrequently, I don't have time to look through the oscilloscope all the signals.
Old 01-12-2017, 02:55 AM
SR2245's Avatar
Did you knock or press slightly on some parts at the PB Amp to provoke the error.
I heard about the same overload error on some 820S units after resoldering the area around the Dolby B/C chip the malfunction never occured again.
But maybe that were problems with the solderings of the additional DolbyS PCB wich is connected in that area too.
Old 01-14-2017, 11:17 AM
Problem was in PB head connector soldering. I don't understand hou and why both channel simultaneously.
Old 01-15-2017, 06:03 AM
yuriy look real close at the solder joint on pin 4 of IC 101. I can't tell without seeing it in person but from the way the pic is I am seeing something that suspiciously looks like it could be a fractured solder joint.
Old 01-18-2017, 03:41 PM
Melon Mango's Avatar
Melon Mango Melon Mango is offline
That's most unfortunate...
I've bookmarked this thread for myself. I just got a CT-S620, and there's nothing wrong with mine, but it's good to have some sort of references in case something does.
Just when I discovered the meaning of life, they changed it. - George Carlin
Yamaha KX-690 "stuck" in record mode eddhead Cassette 0 02-05-2016 10:49 PM
"NAK 500/Goodmans SDC100 Auto stop only working in memory mode". swithers Cassette 5 03-05-2015 12:46 PM
Teac X-10 "stuck" in rewind mode Bluesparks Reel To Reel 2 09-13-2014 07:02 PM
Pioneer CTF 900 level meter "silly" display mode... Strings Cassette 17 02-28-2012 07:08 PM
Can the Akai GX 630D be used in "cue" mode? shobley Reel To Reel 4 09-15-2011 10:29 AM
