Go Back   Tapeheads Tape, Audio and Music Forums > Tape, Taping and Tape Machines > Cassette
Cassette All discussions pertaining to cassette decks. These include general usage, recording, playback and service questions. For subjects related to tape itself, see the Cassette Tape subforum under this one. Obscure service subjects that don't quite fit go in the Help and Do It Yourself subforum.
  #21
Old 01-04-2017, 01:08 PM
vjp62's Avatar
vjp62 vjp62 is offline
I took the supply/takeup spindles off today; whatever lube was on the shafts there before had turned into a sticky, gummy mess, like dried up syrup.
I cleaned this off, put a drop of sewing machine oil on the shafts, and they spin almost effortlessly now. No more squealing, or stuggling during FF/RWD. I also put a drop of oil on the cassette-side of the capstan bearing, and on the drive motor's cassette-side bearing, as well, for good measure.
The second record/playback test looks much better - a lot of the amplitude fluctuation is gone, but there's still some easily audible wow & flutter heard when listening to the 3KHz test tone. The loss of high-frequency response is still there, though... maybe even worse than before.
This test was 30 seconds white noise, 30 seconds 3KHz tone, 30 seconds 10KHz tone. Clearly better than the first test, but not there yet.
I didn't have time to check the power supply voltage levels today; will try to tackle that tomorrow. I might re-cap the main PS electrolytics either way, as they're ~27 years old, and have probably seen better days.
File Type: jpg TD-1200 test 2 - after lubing spindles and capstan.jpg (20.1 KB, 10 views)
  #22
Old 01-04-2017, 03:17 PM
Jonny Ramone's Avatar
Jonny Ramone Jonny Ramone is offline
Jammis Archivivist
Go Bender. Fix that deck.
Akai GX-630D, 4000D,Crown SX-724,Nakamichi BX-300, LX-3, Pioneer RT-2044, TEAC 3300,4010SL,5500, X-700R
  #23
Old 01-04-2017, 08:11 PM
vjp62's Avatar
I thought I'd share some photos, just for reference. The internals look almost identical to the NAD 6340, as lucky pointed earlier in this thread. Compare to his pics in This thread here. Looks like the Carver has a couple of empty sections on the main board, for some reason. The NAD6340 probably has a couple of features not found on the TD-1200. The tape mechanisms appear identical, from what I can tell.
  #24
Old 01-04-2017, 11:10 PM
lucky's Avatar
lucky lucky is online now
Great pictures. Indeed its missing the CAR section near the input plugs and the DynEQ section beside the 6x peak EQ pots.
I recommened a longer run with a dummy cassette for a few hours. This will fix most of the last issues of W&F through sticky bearings.
www.luckyx02.de
  #25
Old 01-11-2017, 10:24 AM
vjp62's Avatar
I've been doing this, unfortunately (even after cleaning the pinch roller and capstan) my W&F problems seem to have gotten worse. On one cassette, a "single" containing about 15 minutes of tape, the W&F is so bad, I am beginning to suspect that it the tape is slipping and being pulled by the takeup reel. I think either the tape is thinner, or the smaller diameter of tape in the cartridge is causing excess torque on the takeup. Or maybe it's a combination of both.
I'm going to short the tape sensor switch, and leave the deck on "play" for maybe 24 hours without a tape, hoping that the sustained mechanical action of the capstan rolling against the pinch roller will help to soften the rubber a little; maybe this will help it grip the tape better. If that fails, from what I've read by perusing this forum, it's probably best to find a new pinch roller.
  #26
Old 01-11-2017, 10:35 AM
lucky's Avatar
The rubber of the capstan can be roughened with a wooden nail file, the wooden ones are excellent for this job and could be split into smaller pieces if needed. Then use naphta for cleaning.
www.luckyx02.de
  #27
Old 01-11-2017, 10:59 AM
vjp62's Avatar
Thanks, I'll try those too and report back with results.
  #28
Old 02-24-2017, 01:58 PM
tagalie tagalie is offline
TapeHeads Newbie
NAD 6340 restart
With the great help of various NAD 6340 threads on this forum, I've taken apart my NAD 6340 to fix a worsening problem - tape refusing to start up without manual help from me, and eventually the door locking shut. Looks very much like a belt problem so I've replaced that.
When I restarted the machine, it played OK first time after a few odd clunks, but hasn't played since. LEDs light up, the solenoid activates, then nothing and it refuses to respond to play or fast forward buttons.
I strongly suspect I messed up some alignments when I took the drive mechanism apart, in particular when I completely undid one of the two screws to allow me to get the belt behind the capstan. The screw that holds the spring undid completely and some things flopped around.
There are two white plastic parts behind the belt, shown in these photos. One moves when the solenoid activates, but the other one, which is tensioned by the spring behind the screw, seems to do nothing. I have a feeling these two are supposed to interact and lost the required contact due to my tamperings. Does anyone have any idea how they're supposed to fit together, or could it be another problem?
  #29
Old 03-09-2017, 04:48 PM
TapeHeads Newbie
Problems solved
Bit disappointed at not receiving any responses re. my problem, but that's forums (fori?) and it's fixed anyway. I think I put something out of alignment, or didn't put everything back together quite correctly when I replaced the belt.
Lessons learned:
In my opinion, it's probably best to take the entire transport mechanism out, rather than trying to replace the belt by only removing two screws, as described elsewhere. Makes the job easier for starters, allows you to do a full lube job while you're at it, and you're more likely to get everything back in correctly.
I've rebuilt amps and electrostatic speakers, but this has been the most finicky job I've ever undertaken on hi-fi gear. All those springs and screws and levers, that flimsy tin plate behind the cassette that must go in exactly right, and to get everything back working you have to reassemble in a certain order.
All worth it, though, tapes are sounding far better than I ever remember, wow and flutter gone. A big vote of support for Marrs belts. I was wary to order from him, looking at some of the shipment issues he's had in the past and the high price of his products. Yes, he was a tad slow getting the shipment off and communication isn't his strong point, but the 6340 belt arrived safely and works perfectly. While I was at it I ordered a belt for my old Sony 302 cd player. I'd replaced the drawer belt on it a few months back, buying a cheapo product, and it worked only intermittently. Marr's belt works like a charm. That old lesson, you get what you pay for.
carver tfm-6c rjag46 Receivers, Amps, and Preamps - Solid-State 4 02-04-2014 05:18 PM
Carver pre amp to Carver pwr. amp? rjag46 Receivers, Amps, and Preamps - Solid-State 4 12-19-2013 03:30 PM
I just discover this forum, I come from Sony insiders forum PhilippeC Mini Disc 10 03-10-2011 09:48 PM
