Go Back   Tapeheads Tape, Audio and Music Forums > Tape, Taping and Tape Machines > Ones and Zeroes
Ones and Zeroes Digital tape is still tape! Want to discuss DAT, DCC and blank media? This is the place.
Old 11-19-2016, 01:32 AM
Linnovice Linnovice is offline
Tascam DA-30 Problem
Hi all, does anyone have any knowledge of tape loading problems on a Tascam DA-30 DAT machine. I've just bought one from that popular auction site. It's cosmetically in good condition but has a loading problem. When a cassette is inserted it tries to load but immediately ejects. I've taken the case off and it seems that the tape is not being taken out to the revolving head. Is this a simple fix or major surgery?
What is the general opinion of this machine? Worth repairing?
Regards
Mike
R2R=Studer A807 MkI & II, Revox PR99 MkII, Revox A77 MkIII 4 Track, A77 2 Track HS, A77 2 Track STD, Tascam 42B, Tascam 32-2B, Teac 3440 and 3340S
Small Scotch, Hearing aids and Happy Ears
Old 11-19-2016, 01:56 AM
hdrobien hdrobien is online now
All the DA 30 I serviced suffered from old dried grease in the tape loading mechanism.
Needs full and painfull dismantling, cleaning and relubing (light).
You also need to clean (deoxit) the sliding potentiometer on the right side of the mecha. It is a kind of encoder to tell the logic about the loading process.
No known issue on the loading tray.
Nikko ND-790 990 800 1000, Teac V-1RX V-2RX V-970X, Z-5000, Continental Edison LE 9965, Alpage FL-8000 AL-300, Dual C844, Akai GXC-760D GX-95, Nakamichi 582Z, Sony TC-FX7 FX1010 K555ESII K666ES K777, Hitachi D-3300M, ITT 8025, JVC KD-A8 DD-7
And more than 20 DAT !
Old 11-19-2016, 07:14 AM
Skywavebe's Avatar
Skywavebe Skywavebe is offline
Skywave Tape Deck Repair
They could use cleaning but they also suffer from stretched belts which are very small. The loading problem can be fixed.
Best regards,
Sam Palermo, BSEE , ProSquad Member
Skywave Tape Deck Repair- Chicago area
(630)616-0932 Office/ Email skywavebe@sbcglobal.net
Past Teac/Tascam Lead Service Technician at Chicago Factory Service still doing repairs.
http://s609729863.onlinehome.us/tape...uipment-repair
Now accepting MC, Visa, Amex & Discover Cards!
Old 11-19-2016, 07:22 AM
The belt problem is almost only with the DA-30 MkII which has a totally different mecha.
On the DA-30 "1st edition" the little belt which move the guides (4-11 in the service manual) does not stretched, but eventually slips because of the stuck mechanism. Usually the gears "jump" before and you can sometimes hear "clac clacl clac".
Old 11-19-2016, 10:07 AM
Elite-ist's Avatar
Elite-ist Elite-ist is offline
Mike: My Tascam DA-30 is suffering the same symptom. I hadn't used it for more than a year, and I intend to bring it in to be serviced by a technician. I was prompted to use it again because I received a mix tape from Pat (Glantoir). I did pop off the cover and watched it while loading a tape. I viewed the on-line tutorial on how to change the loading belt for the DA-30 MK II, thinking the DA-30 was similarly constructed, but it looks like it isn't from what is being discussed, here.
Here are a few videos of the last time I used it:
Click on image to play video:
Nando.
Old 11-19-2016, 10:19 AM
They are indeed very different.
Beside the loading tray which is the same and the audio board which is similar everything else is different.
The MkII seems very reliable beside the small belt. Never found another issue (once a 7805 voltage regulator that was out).
Old 01-11-2017, 12:42 AM
Hi all, I've now spent quite a while removing some really sticky and hardened grease and re lubricating with some light oil (just so that the mechanism runs without any dragging, it will be lubricated with the appropriate grease later.). The transport now appears to be working ok. The cassette loads, a loop of tape is taken out and wrapped around the rotating head and the head spins up. Problem I now have is the logic buttons for the transport are not working so I can't get it to play/record. FF/RW, PLAY all inoperative. The other buttons under the display as well as the display itself all seem good. Any suggestions? Cheers, Mike
Old 01-11-2017, 01:37 AM
I would check on U701 if the buttons trigger something.
Old 01-11-2017, 07:19 AM
Skywavebe's Avatar
These are like little VCR decks. They often have state sensors and end thread limit switches. Before I go changing any chips which are probably fine and waste money on parts that are not needed, I would go looking for why the keyboard is being ignored. This is probably because the controller does not think the tape is fully threaded yet.
This is more common a problem than a controller IC going bad.
Best regards,
Old 01-11-2017, 09:38 AM
Indeed a defective IC is very unlikeable.
But you have to check first that the buttons are connected to the IC and that the IC sees the button signal.
Mode switches are also to be considered but from my experience of these machines the controller usually tries to eject the tape when something is wrong.
Anyway you can spray some deoxit in the main mode switch which is located on the right side of the mecha (item #17 in the exploded view 4, linear slider).
problem with Tascam 103 Sonichermit Cassette 0 10-28-2015 12:02 PM
Tascam 48 ob -- PROBLEM halljack Reel To Reel 3 06-15-2014 04:33 PM
Tascam 22-4 problem banighs Reel To Reel 2 06-15-2013 09:31 PM
Tascam 234 rec/pb problem thepolg Reel To Reel 0 03-29-2013 10:14 AM
Tascam 32 Problem najm0004 Reel To Reel 5 11-02-2009 11:12 AM
