Old 04-21-2017, 12:23 AM
DeloArias DeloArias is offline
Need Help: Yamaha TT-400U canīt play records
Hello everyone, I write this post to search for help with my turntable.
I bought it some time ago, but it doesnīt work properly. When you put the Lp the arm aproachs it to play it, but it never falls into the groves and goes back, standing near the disc and never playing it
Here is a video to show the problem: https://www.youtube.com/watch?v=E6UjCJHg4ls
My knowledge about electronics itīs minimal and i canīt fin any information that helps me to fix this so I ask here for help.
Thanks for reading and enjoy the music
Old 04-21-2017, 02:41 AM
svampen's Avatar
svampen svampen is offline
In loudness we trust
I would start with the internal mechanics. There are a lot of levers, springs and cogwheels that work together to enable the automatic features.
Clean out old lubricant and give the inside some general TLC.
Old 04-21-2017, 05:50 AM
Have you tried looking for a schematic? It may be available on hifi engine or down below at stereo manuals. Below the posts is a list of sponsors as links, just tap on the appropriate one to access their site.
Hifi engine e.com is free, you just need to register. Stereo manuals is a paid site, but the quality is so much better than hifi engine as hifi engine's scans are all over the place quality wise.
As said already, it's mechanical. You can also use this deck manually as well I'm sure. That would mean manually setting the arm down by hand instead.
I st likely needs old grease cleaned out and decreased with lubriplate 105, a quality grease that does not turn to glue like the old stuff does.
Good luck!
Old 04-21-2017, 08:27 AM
JimTimP's Avatar
JimTimP JimTimP is offline
Don't Be Square - Sine Waves Dude!
Have you tried a record not so badly warped? It looks like the cartridge gets hit by the warp and all stops.
Retired USAF, Solder Melter. Not to old to Learn, Teac X-2000R, Otari MX-5050 BIII-2 (X2) and BII-2H, Manley Stingray II Amp, Yaqin SD-32A CD Player, Zestos Andros PS 1 Phono Preamp, VPI Prime Signature, ADS & 16.5, Soundsmith Voice & Lyra Delos on Separate Arms VPI 3D Tonearms, Madisound Zaph ZRT 2.5 Speakers, PS Audio P5 Power Station, Dual Homemade 10" Subs, JTP Cables
Old 04-21-2017, 01:25 PM
Yeah, jaja. Sorry for the warped record, but yeah I tried with some other (before and after this record) in so much better conditions, but it simply doesnīt work. The arm doesnīt fall on the groves, it only tease me xD.
Good luck!
I search on HifiEngine but they only have the owners manual, not the service :(. Still i will make the posible for buy the service manual on the StereoManuals (i think that they got it, but i will ask). And i will do the cleaning and the lubricant change, I want to make it work.
Really, Thanks :D
Old 04-21-2017, 02:20 PM
svampen's Avatar
Hm. On the other hand, I read this TT have some automatic detection of the record size.
In the vid it seems to go beyond the first track and then slowly out again, like it is looking for something.
The behaivour might be caused by it is not "seeing" the record?
Might be something blocking the sensor? It is probably some sort of light/reflection sensor around the area where the needle is.
Old 04-21-2017, 10:27 PM
A sensor? Were did you read it? And were is it? I never saw it. Let me check but, it has a button were the plate goes, and it gets pressed when the LP is on top. Thatīs the sensor?
Old 04-22-2017, 11:38 AM
archeo archeo is offline
Originally Posted by DeloArias View Post
A sensor?..it has a button were the plate goes, and it gets pressed when the LP is on top. Thatīs the sensor?
Yes that is it. To me the behavior seemed too, like the size sensing is not working.
Tape Decks: 2x Marantz SD-60, 2x Philips FC-870, Turntables: Philips F7610, Siemens RW666, Tesla NC452, Amp: self made, Boxes: active Visaton
Old 04-22-2017, 12:27 PM
NEMOaudio's Avatar
NEMOaudio NEMOaudio is offline
In stop mode try to push down the arm lifter with your finger, see if it goes down smoothly. If it was sitting unused the arm lifter might not work smoothly so you have to press it down several times before trying to play.
The Stereo Museum www.1001hifi.com
Old 04-22-2017, 12:37 PM
Like everything else, if you don't use the gear for a long while, grease etc will dry up and seize and will require you to clean out and relube.
This also goes for the lift as it is either grease fitted, or hydraulic (a viscous oil inside a shaft with a plunger that forces the lift to be damped to slowly lower the arm) though many automatic players use a mechanically greased mechanism for raising/lowering the arm.
Old 04-23-2017, 02:31 PM
Um... i donīt know. The mechanism seem to work well, the button get pressed but i donīt know...
I tried pressing the arm lifter but is all the way down. I tried moving the adjusting screw but doesnīt do anything, then i try to lif it all the way up and I can but when I release it, the arm lifter falls all the way down.
Heads on Yamaha decks? Yamaha. GF CF. gate28 Cassette 13 01-08-2017 09:15 AM
Yamaha KX-250 squealing on play phonik Cassette 7 01-20-2016 08:01 AM
482Z play circuit gain for repaired play head df_genius Cassette 0 11-20-2015 05:03 PM
Yamaha KX-393 play trim control norrie Cassette 13 09-09-2013 05:26 AM
Strange problem, records in stereo but only play right side Toshito Cassette 2 06-08-2013 11:22 AM
Copyright Đ2018, Tapeheads.Net. All rights reserved, no use of any element incorporated into this site without express written permission.
