Old 09-11-2017, 05:24 AM
Gerryherft Gerryherft is offline
Kenwood KD650 Turntable
Hi, Had that unit for close on 35-40 years and for the last 20 years it hasn't been used. It has a Rotel headshell and a stanton 300 stylus/cartridge........if those are the correct words. Heavy marble type base and original lid. Anyway took it out and plugged it and in and it started with seemingly no problems. Haven't put a record on it yet, but before I do. Is there anything I should do to make sure all is Ok....lubrication, cleaning etc. It has been well looked after and well stored but just not used. Also is it a good unit and worth keeping (along with My Otari MX50050 B2 R2R and Luxman SQ507x and Nakamichi 1000 II) Going back to analogue. Look forward to your helpful replies. Thanks in advance. Gerry
Old 09-11-2017, 06:43 AM
bolly's Avatar
bolly bolly is online now
You bet all those units are good stuff!!
I use kd650 as well, rare table usually fetches $500usd!!
I have a hard copy of the service manual and haven't done much to mine in 10 years, other than repair the dampening mech. You should be able to download owners and service manuals at vinylengine.com
Old 09-11-2017, 09:03 AM
Mark J's Avatar
Mark J Mark J is offline
Burning Tape
That KD-650 is the best unit in your list. As Bolly said it is a great table. Although I prefer the ergonomics of the earlier non-quartz locked KD-500/550, the KD-600/650 is a better table. I've had all but the KD-550. the 50 indicates it came with a tonearm and the arm Kenwood supplied is a very good one.
There isn't any maintenance required to put the unit back in service if all the lights are working. If you need lights, there are 4, I think, just use the table and enjoy as they just indicate the unit is on and then if the speed is locked or not.
The headshell and cartridge are the low points on that unit. It can for sure use some of the best cartridges available today if you want to go that direction as you get further into the enjoyment of records. Don't get too concerned about finding a KD-650 replacement headshell, for the cost on the bay, when found, you can get a very nice aftermarket unit if the Rotel isn't a strong, rigid unit, don't know, can't see it. But that table deserves a decent headshell, probably with azimuth adjustment. Heck if you jump in deep enough, just swap out the tonearm and move that table up the performance curve as far as you like.
But first, kick back, relax and enjoy a truly great turntable.
10X, 10XD, C300, CD-301, K-12, K-112, K-117, MXD-D3 (x2), MZ-N707, MZ-G750, 7525, RC-9, RS-20, SX-724, TCD-330
Old 09-12-2017, 09:20 AM
bolly's Avatar
I'll make a suggestion, even if the hinges are cracked now, disconnect them and just lift the cover off and on... If they're not cracked still disconnect them as they break easily and are very rare!!
Make sure you balance the tonearm correctly too... how's she spinning??
Kenwood (Trio) P-7X full auto turntable problem yuriy Turntables and Vinyl 7 09-06-2017 05:47 AM
Kenwood KD-5066 automatic turntable issue. kenwoodlvr Turntables and Vinyl 6 03-16-2016 07:04 AM
Kenwood KD-3055 Turntable turning too fast. Robert E Turntables and Vinyl 5 07-03-2015 11:19 AM
Kenwood KX/KA/KT-400: matching turntable ypsilon Turntables and Vinyl 2 11-19-2013 02:18 PM
