Old 09-01-2017, 04:35 AM
yuriy yuriy is offline
Kenwood (Trio) P-7X full auto turntable problem
Kenwood (Trio) P-7X full automatic turntable problem, the only problem with this record, other records are determined correct size.
https://youtu.be/mDX9Xl6kUZA
Old 09-01-2017, 01:05 PM
NEMOaudio's Avatar
NEMOaudio NEMOaudio is offline
I have the same problem with a FISHER tangential turntable. Press PLAY and it goes to the end of the record without lowering the arm then returns and stops.
The Stereo Museum www.1001hifi.com
Old 09-01-2017, 01:24 PM
My player works fine with other records. And lowering the arm on problem record, but start from smoll size.
Old 09-02-2017, 01:33 AM
You have sensor problem or sensor amp.
Old 09-05-2017, 04:52 AM
Without any repair began to work with this problem plate.
https://youtu.be/RpDlRFdLSW4
"normal" plate
https://youtu.be/sfW8E0nVQgo
from the very beginning was checked the contact in trimming resistors, a few turning back and forth.
Old 09-05-2017, 07:17 AM
Wooden needle to verify head.
Old 09-05-2017, 10:40 AM
I am not sure what the problem seems to be, the OP post is confusing, however, if the real question is: why his automatic turntable does not correctly identify a particular LP,
then the answer is that all automatic ones have LPs that do not like, and the sensor adjustments have to be set up accordingly.
For instance, one solution coming from factory for some Technics turntables is to to provide a green matte to be placed upon the rubber (black) one - this, according to Technics, improves the detection of an LP (in particular the coloured ones) and avoids the needle to drop upon platter and get damaged.
If only the start is wrongly identified maybe this is your problem.
If the pieces are not correctly identified (including the first one) then you may have a displaced position, which is correctable by adjusting the string of the arm (lots of tests needed).
And it may be that some players cannot be set to accept eg 45rpm with 12", only with 8".
Old 09-06-2017, 05:47 AM
To check the head was glued wooden replacement needle
Vintage Trio/Kenwood deck, sweet RobHolt Turntables and Vinyl 5 06-19-2016 07:01 PM
Kenwood's Auto Bias feature Chris G Cassette 12 04-15-2015 02:24 PM
Full auto Tech 19 CanJet Turntables and Vinyl 7 04-30-2014 04:07 AM
