Universal Capstan Motor
Go Back   Tapeheads Tape, Audio and Music Forums > Service, Restorations, Helpful How-Tos, Parts and Manuals, Ads and More! > Help and Do It Yourself
Help and Do It Yourself Got a technical problem or question that doesn't belong in any of our ordinary categories? Ask it here.
Old 09-08-2017, 03:47 PM
nbbk75's Avatar
nbbk75 nbbk75 is offline
Transistor replacements
Hello
Anyone know a good replacements for 2SD2037 and 2SB1357, found in RS-B965?
If there is some with mounting hole that would be even better.
Technics SU-C909+SE-A909, SL-PS7, RS-AZ7, RS-B565, 2x RS-B965, SJ-MD100, SV-DA10, SL-1200MK2
Pioneer GR-777
Sony MDS-JB730
Old 09-08-2017, 09:48 PM
390FE 390FE is offline
Check out this site https://alltransistors.com/transisto...ansistor=18991 and here https://alltransistors.com/crsearch....=60&caps=TO126
Just enter the 2SB # on the site for it's sub.
It does an ok job for subs BUT you still need to double check and verify for application by looking at the datasheets for the suggested sub vs the original.
Hope this helps.
Old 09-09-2017, 05:45 AM
williamsunique williamsunique is offline
https://vikiwat.com/search.en.html?p...CategoryID=659
https://vikiwat.com/en/transistor-2s...w-to220fn.html
Paul
Old 09-10-2017, 01:25 PM
nbbk75's Avatar
Hope this helps.
Thanks for your answer. I have seen that page, but wondering if somebody already used some substitute and can confirm that it is good replacement.
Thanks Paul, site looks nice, but can they be trusted ? There are many Chinese el.parts on eBay. Purchased something from them ?
Pioneer GR-777
Sony MDS-JB730
Old 09-10-2017, 03:24 PM
I have used that site I gave to do some crosses on some transistors & didn't have a problem. But I did double check the spec sheets for the subs against the spec sheets for the originals.
What are these transistors used for? Are they being used for power supply applications or for audio signals? I am guessing they are being used in a power supply section. Usually/most times you can put in a higher/better rated part with no issues.
Lapping heads when replacements aren't available ajmich Reel To Reel 12 08-12-2016 05:13 AM
Can You ID These Old Caps, Recommend Replacements?? MarkC Help and Do It Yourself 5 08-26-2015 11:05 AM
Meter Lamp replacements for Tascam 42's gamve Reel To Reel 4 12-14-2012 05:57 AM
I need replacements for zooterman Reel To Reel 5 08-08-2012 02:12 PM
Tascam 244 knobs..where to get replacements? GetReel Cassette 0 10-05-2011 03:00 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright 2016, Tapeheads.Net. All rights reserved, no use of any element incorporated into this site without express written permission.
