Old 02-13-2018, 10:06 AM
srmeister srmeister is offline
Hum on Sony TC-KE500S
I know people will say its a cheap deck, but i like it so far. I replaced the belts and the cracked gear which is typical for this mechanism (TCM-190). By the way there are replacement gears available.(Look for Module 0.4, 17 teeth, 2mm bore).
There is a hum on the unit that is from the 50Hz outlet, 50hz and its harmonics. It is noticeable even on new blank tapes, so it must come from the internal electronics, not the tape itself. The amp/PC and tapedeck are connected to the same outlet. The hum appears only on playback.
Somehow the 50hz gets into the tape amp.
Do you guys think there is a way to improve the situation? Adding some filter caps on the power supply output, maybe?
On the picture you can see a spectrogram of a playback of an empty tape with Dolby S enabled.
Old 02-13-2018, 11:42 AM
I recognized, the problem with the hum when connecting the deck to the amp can be dealt with by moving the deck away from the amp. So this part is solved. Still i have the hum when the deck is connected to the on-board sound card on my PC. Nothing changes if i move the deck around. Somebody has some advice for me? I need my PC for recording. Maybe a USB Soundcard will help?
Old 02-13-2018, 12:54 PM
hdrobien hdrobien is online now
It is probably a ground problem.
With an insulated tool, try to "push" on several places of the main board, especially near the screws holding the board, and the connectors.
By the way could you be a little bit more precise about the gears ? Where to find them ?
Nikko ND-790 990 800 1000, Teac R-777X V-1RX V-2RX V-970X, Z-5000, Continental Edison LE 9965, Alpage FL-8000 AL-300, Dual C844, Akai GXC-760D GX-95, Nakamichi 582Z, Sony TC-FX7 FX1010 K555ESII K666ES K777, Hitachi D-3300M, ITT 8025, JVC KD-A8 DD-7
And more than 20 DAT !
Old 02-13-2018, 01:24 PM
Here in Germany/Europe it is available as "Weinert 9614" Two pieces for around 3€ + shipping on ebay. These fit and work perfectly. They are made from red plastic instead of white.
If you live elsewhere, you could just google for it. Like i said, look for 0.4 Module (metric) and 17 teeth, 2mm bore and at least 2mm wide teeth(up to i'd say 4mm)
Sony TC-KE500S Repair Scott1 Cassette 0 03-15-2017 11:28 AM
Sony TC-KE500S Big Kelv Cassette 3 12-11-2016 11:27 AM
Sony TC-KE500S Rew/FFW problems tabpat Cassette 2 03-21-2013 02:16 PM
Sony TC-KE500S Nightingales Cassette 0 03-05-2013 03:17 PM
Sony TC-KE500S Web Police Cassette 8 08-05-2009 04:45 AM
