Go Back   Tapeheads Tape, Audio and Music Forums > General Audio Discussions > Receivers, Amps, and Preamps - Solid-State
Receivers, Amps, and Preamps - Solid-State The heart of every system. Discuss your amps, receivers and control amplifiers here.
Old 11-14-2017, 10:19 AM
Tangled Tangled is offline
Kenwood KA-550D Amp Volume control
Hi All,
I've picked up a Kenwood KA-550D amplifier which I intend to use in a basic system in my office.
Before I start moving things around and start setting everything up I wonder if someone can help on the following, just in case its faulty.
On the volume control there is a separate rear rotating knob, which appears to be a balance control, just out of the top of pic it reads left right.
There is no separate balance control on this amp.
When I rotate the volume control, the rear knob also travels with it, both knobs are quite stiff, but they can be rotated independently.
If it's a balance control I would have thought it would have stayed in position.
Online manuals just refer to it as a volume control.
(I have another Kenwood amp which also has this rear knob, which remains in position but doesn't seem to affect volume, but it does have a balance control).
If anyone can advise before I start lugging stuff around it would be great.
The obvious thing for me to do is set it up and check it, but I'm trying to avoid that to save disruption.
Thanks All.
Old 11-14-2017, 11:09 AM
kcbluesman's Avatar
kcbluesman kcbluesman is offline
Turn it up!
It is the balance control, and it has simply stiffened with age/dirt/oxidation. Deoxit 5, followed by Deoxit FaderLube will solve your problem. You will need to open the case to get to the ganged pots. In other words, they use a single shaft to control both the balance and volume pots. Cleaning and lubricating the pots will loosen things up and allow the balance to work independently from the volume.
Old 11-14-2017, 11:56 AM
NEMOaudio's Avatar
NEMOaudio NEMOaudio is offline
You haven't posted a usefull picture but the answer is easy.
That's a volume knob with separate left and right channel adjustment on the same axis (as printed above the knob).
In this case you have no separate balance control you adjust left and right channels independently if necesary.
The Stereo Museum www.1001hifi.com
Old 11-15-2017, 12:37 AM
Many Thanks Both,
I thought it was the separate balance control, just checking in case it was something more sophisticated. Will give it a good cleaning.
I
Old 11-15-2017, 01:54 AM
NEMOaudio's Avatar
Remember that they have to turn together even if you're holding only one of the rings.
You only need cleaning if it's noisy.
Old 11-15-2017, 03:02 AM
So, when I rotate the volume control knob, the rear balance control should travel with it and not stay in position?
(I should really do a quick rig up)
Old 11-15-2017, 07:59 AM
kcbluesman's Avatar
Turn it up!
The volume knob is supposed to turn independently from the balance knob. I dont know what nemo is talking about. Cleaning (deoxit) and lubricating (faderlube) will definitely help the two to turn independently more easily.
Old 11-15-2017, 08:22 AM
What's happened is that the grease in the shaft and sleeve assembly has turned gummy and the one shaft is now also turning the inner sleeve because of the adhesion. Usually, the naphtha in the D5 will work on the coagulated grease if you can get some in down the shaft. After it breaks loose, put ONE tiny drop of oil at the gap and work in into the shaft by rotating the controls. Eventually, it will work its way into the old grease and keep it soft. The naphtha does it initially, but it evaporates and the effect doesn't last. That's where the drop of oil comes in.
Old 11-15-2017, 09:18 AM
NEMOaudio's Avatar
Originally Posted by Tangled View Post
So, when I rotate the volume control knob, the rear balance control should travel with it and not stay in position?...
Originally Posted by kcbluesman View Post
.... I dont know what nemo is talking about. ....
There is no "traditional" BALANCE knob on this model.
You have independent volume level for Left and Right channel.
They were designed to rotate easily together.
For "balance" you hold one ring (channel) while adjusting (turning harder) the other for a "perfect balance"
Haven't you turned this unit on and hear how the volume increases in both loudspeakers only if they move together ?
Old 11-15-2017, 09:56 AM
Thanks All.
I didn't expect to cause controversy and receive so many answers.!!!
I'll do the acid test tomorrow if I have time.
Will rig up a simple set up and report back.
Old 11-15-2017, 10:06 AM
kcbluesman's Avatar
Turn it up!
Either way, the answer is the same. Clean and lubricate, as Pacific and I described.
Old 11-15-2017, 12:23 PM
Well, be careful. Now that I see a close up, those two controls are supposed to be coupled together. They should both move when you move the outer knob, but should be loose enough that you can independently adjust them. If they work that way, then I wouldn't do what I suggested.
Old 11-18-2017, 07:01 AM
Thanks for all the comments and assistance.
Well the answer is :-
The two knobs rotate together.
The front knob is volume, the rear knob is balance, which you set independently to the left or right of the front volume red light by holding the volume knob.
When you turn the volume knob the balance knob travels with it, keeping the balance constant.
Old 11-18-2017, 08:26 AM
Mmmm, no. A conventional balance control attenuates one channel when you rotate it. Conventional volume controls move attenuate both channels identically, and when coupled with the balance control, work to keep sound levels the same between the two channels if there is some sort of difference.
In this case, you lack the balance control, but the volume controls are able to be offset from each other yet still coupled, which performs the same function as the conventional setup but with one less control and saving some cost.
Old 11-18-2017, 09:55 AM
Thanks P.S. I think I understand what you mean.
It's all set up now and working fine.
Silly question: how to control output volume juanmoreno Cassette 12 04-25-2017 11:59 AM
Automatic Volume Control: Makes Me Sick! meezer Mobile Audio 22 07-24-2016 05:17 PM
Best (simplest) 6mm headphone volume control for DR3? gekigami Miscellaneous 6 06-08-2014 11:04 PM
Scratchy Volume Control Outland Receivers, Amps, and Preamps - Solid-State 11 12-17-2012 07:05 PM
