Go Back   Tapeheads Tape, Audio and Music Forums > General Audio Discussions > Tube Gear - Preamps, Power and More!
Tube Gear - Preamps, Power and More! Bottleheads unite! This is the place to talk about that tubular gear of yours.
Old 10-18-2009, 02:48 PM
Socal Sam's Avatar
Socal Sam Socal Sam is offline
Serious AudioHead
McIntosh MC75 Nudies!
I've been chasing an intermittent gain problem so I had the bottom off to burnish the RCA jack. Problem solved, do far. While I had it open, I thought I would share a couple of photos.
The fourth photo shows the serial number. This is a 75-10xxx serial number which I understand is a 1961 production model. Wow, great sound perfected 48 years ago!
Old 10-30-2009, 07:04 PM
Socal Sam's Avatar
Serious AudioHead
A quick update on this amp. The intermittent gain problem kept coming back. At first, I thought it was a dirty and misaligned RCA jack. Then I re-soldered the ground wire from the pot to the chassis. Then I took a bigger swing and re-soldered a bunch of suspicious joints. Each time, the gain was normal afterwards only to ebb after a few days. This time, I checked everything and found that one of the original solder joints was touching the pot housing, which in effect was causing the input signal to ground. GRRRR...
Old 11-02-2009, 12:27 PM
Naknut's Avatar
Naknut Naknut is offline
Thumbs up
PITA no doubt but your persistence paid off.
Nakamichi Dragon (photo by and courtesy of king crab) 700 600 500 LX-5 BX-300 BX-2 BX-100, Yamaha KX-1200U, Akai GX-F91, Pioneer CT-F950 CT-M50R, B&0 Beocord 9000 Sony TC-K890 ES
Concept 12.0D restore (and nudies!) Pacific Stereo Pacific's Restorations 16 10-16-2017 10:22 PM
BGW Pro 250D Nudies Eminence1963 Receivers, Amps, and Preamps - Solid-State 3 06-22-2013 04:56 AM
sony tcr302 single well nudies ke4mcl Cassette 2 03-19-2012 09:36 PM
McIntosh MC60 and MC75 Photos Socal Sam Tube Gear - Preamps, Power and More! 1 11-18-2009 11:08 AM
McIntosh MC75 Monoblocks! Socal Sam Tube Gear - Preamps, Power and More! 16 10-16-2009 11:34 PM
