Old 03-14-2016, 05:36 PM
powerdoc powerdoc is offline
Revox A77 power supply board connection problem
So I had to replace the fuse holder for f102. To do same I had to remove some of the connectors on the side of the power supply board where the fuse is. When I reconnected the leads the top connector on the board is empty. I wrote down the color scheme of the leads but failed to notice if there was an empty connector. I looked in the service manual but don't see a pic with the leads connected. Did I screw up something again?
Old 03-14-2016, 07:03 PM
tubenirvana's Avatar
tubenirvana tubenirvana is offline
audio nut & TH supporter
have a look at this photo, note the left most connector is not used...is this what you are asking about?
Certified Tube Gear and Analog Nerd!
Revox A77, B77, PR99, A700 & B225 upgrade kits, parts & customizations
Handcrafted, custom tube home audio gear
WWW.ERHARD-AUDIO.COM
WWW.REVOX-R2R.COM
Old 03-15-2016, 02:13 PM
Actually, it's the board which is vertical and the empty connector is the most superior one. Can't see exactly on yours if it's empty or not. Thanks!
bench top power supply knownothin Test Equipment 11 03-09-2016 10:59 PM
Teac A2300SX - how to re-attach power supply PC board? 62vauxhall Reel To Reel 18 06-17-2014 08:39 AM
Revox B77 Power Supply Problem/Previous Owner Modded Alan P Reel To Reel 3 12-30-2013 09:22 AM
Teac A-3440 power supply problem Crawford Tillinghast Reel To Reel 10 09-11-2012 04:11 PM
Crown Pre, power, switcher, power supply Mark J Complete Systems 10 07-24-2010 05:48 PM
