Go Back   Tapeheads Tape, Audio and Music Forums > Tape, Taping and Tape Machines > Other Tape
Other Tape Any analog format other than cassette or reel to reel; 8-track, Elcaset, microcassette, VHS, etc.
Old 10-12-2017, 12:26 PM
AlbaSCR240's Avatar
AlbaSCR240 AlbaSCR240 is offline
Runrig Fan
Location: Some small village 60 odd miles away from Glasgow
Reelspin Funai VCR not working properly...
I have this Funai 21B-200 VCR (All scream in horror) which seems to have a slight issue, when rewind the supply reel does not spin but the take-up fires the tape out into the head which seems to have a sticky substance on it causing the tapes to get stuck on it (also does not insert tape into cassette). What do I do? Ive had the following error codes: 1, 3 And 4, does anyone know what these codes are, do they mean anything major. I will politely ask anyone with experience with these plastic nightmares to step forward and help!
Many thanks,
Ryan
Old 10-12-2017, 01:27 PM
JVRaines JVRaines is offline
Error codes mean the transport is not moving as expected. In other words, things are jammed up as you can see for yourself. Now, what has the sticky substance on it? The head, the takeup reel, or the tape? Which head?
Old 10-14-2017, 10:55 AM
AlbaSCR240's Avatar
Runrig Fan
Sorry I could reply quicker, I used some isopropyl alcohol on the parts that had the substance, it is gone but the picture is in Black and White and jumps around the screen a lot
Old 10-14-2017, 04:58 PM
I spent a lot of hours working on Video decks through the years. One Funai that Teac sold stumped all kinds of people and what I found was the real problem was that a rubber bumper in his case was either compressed or shrunk and made the mechanism go out of tolerance- I put a new bumper on and the deck worked like new- 6 hours and now we know. The answer can be there but the time is needed to find out what the real problem is.
Video heads can be contaminated quickly but should be able to be cleaned just do not use cotton swabs and not to rub up and down which will break the head off. Sometimes dirty heads can stop the Chroma and let the Luminance through. Some cheaper decks had a relay in a shielded box that when tapped would give back a signal. The grease in guide track can harden and get in the way of the thread or they could be out of adjustment.
You need a scope on the RF test point to adjust them with the trigger on the switch 30 sync TP. If you look at a NTSC waveform on a scope you can see if the Chroma Burst is present. If not then no color.
Waveform will be similar to PAL just different rate.
Old 10-14-2017, 11:17 PM
Jeepwalker Jeepwalker is offline
When it comes to VCRs, the first thing is to make sure everything is clean and free of deposits. Use isopropol alcohol, but stay away from the little heads on the round spinning drum. Clean the drum carefully, but don't go anywhere NEAR the heads (those little slots) with the cotton swab. Heads are tiny and brittle and break easily (if you break one, you're screwed!). Make sure ALL parts where the tape go are hermetically CLEAN, especially the metal capstan and rubber pinch roller. Let it all dry and try it again.
Look at other things too. Like, is the display flickering or dim? Are any of the capacitors near the power cord (power supply) leaking good or domed at the top? Do you see any burned or dark areas on the power supply board? Power supply issues are common (especially dry or leaking capacitors) and lead to voltage drops which screws up the IC's logic circuits and ultimately makes VCRs act 'goofy'.
Then there are the possibility of mechanical issues too (belts, mode switches, gears, etc).
Start with cleaning first ...VCRs need to be absolutely clean to work properly!
Old 10-15-2017, 01:08 PM
You may also have shedding tapes. If that's the case, you will need to clean the tape guides inside the cassette shell as well as your VCR. Also, remove the reels and subject them to dry heat at 135 F for 12 or more hours. This is most easily accomplished with a food dehydrator; don't use a gas oven because they produce a lot of moisture, which is the enemy.
Old 10-16-2017, 02:27 AM
Never heard of sticky shed syndrome (SSS) occurring to home VHS tapes, which is what the heating treatment is supposed to "cure" (actually, it just stabilizes the tapes enough for transfer, it doesn't fix them forever). AFAIK it only happens to specific audio and video open reel tape formulations from the 60s and 70s.
That being said, VHS tapes can go bad and foul up the delicate VHS heads for various reasons, including going moldy, nicotine-stained, or simply the formulation breaking down. In such cases, simply toss the offending tapes, as there's very little one can do at home to recover them, especially when a delicate transport is involved. If the material that's on them is valuable, a professional recovery service is your bet bet.
Old 10-16-2017, 02:40 AM
Assuming the deck is in its perfect state, these may also be the symptoms of a wrong TV system.
However, this deck I wouldn't not get even if I would be paid 100 (ok, maybe I'll keep the money and dump it in the bin in the dark night when everybody sleeps, of course, apart from the 72 years old neighbour lady )
When you'll realise that spending money on these schrott is nothing than spent money with no gained benefits? Pay 20-30 for a decent JVC/Panasonic/Sony and live happy and trouble-free...
Old 10-16-2017, 11:33 AM
"The formulation breaking down" is exactly the problem of soft binder syndrome. It afflicts various tapes manufactured into the 1990s. The only brand of sticky VHS tape that I have encountered is Ampex 189. I am also encountering unplayable U-matic cassettes from the 1980s.
tape counter stopped working properly pete30 Cassette 4 12-26-2017 02:28 PM
Otari MX5050 BII Play button not working properly Gerryherft Reel To Reel 2 11-14-2016 10:13 AM
Marantz sd-60 left channel not working properly aerodeck Cassette 20 11-26-2015 12:26 PM
Boombox tape player - take up reel not working properly, chewing tapes castlefreak Cassette 14 01-11-2015 03:11 PM
Roberts RTR, Not Sure if working properly? tyqre Reel To Reel 6 08-23-2013 08:16 AM
