Old 01-11-2017, 01:32 PM
carzamerica carzamerica is offline
Revox A77 transport issue, any ideas ?
Hello been playing or trying to a Revox a77 mk111 1/2 track.
Was supposed to be running fine and has replaced caps.
play, ff play and record do nothing, it does rewind, which is weird that it does that but not the others, but dont know. Have other decks including a 1/4 track A77 also mk111. tried a few tapes, work fine on others but not on this one.
Any thoughts, thanks, Ben
Old 01-11-2017, 01:59 PM
Might need a new transport relay board. They have caps that can go bad. This might help you.
http://www.ebay.com/itm/112263083983...84.m1555.l2649
Old 01-11-2017, 02:11 PM
Thanks for the tip.
Old 01-11-2017, 03:44 PM
Challenger604 Challenger604 is offline
Banned
Hi there!
Your description is not very clear! Can you try again please??
Relais are very reliable. Would be surprised...
Cheers!
Old 01-11-2017, 05:10 PM
tubenirvana's Avatar
tubenirvana tubenirvana is offline
audio nut & TH supporter
we are assuming that you have the dummy plug installed in the remote control socket at the top?
Also, check your 27VDC or so supply and its fuse.
Certified Tube Gear and Analog Nerd!
Revox A77, B77, PR99, A700 & B225 upgrade kits, parts & customizations
Handcrafted, custom tube home audio gear
WWW.ERHARD-AUDIO.COM
WWW.REVOX-R2R.COM
Old 01-11-2017, 05:18 PM
Perryed Perryed is offline
Location: Springfield MO Actually live next door to the Simpsons! But no Homer.
Hope you find out what it is. I just recapped mine and it actually worked fine beforehand. Now, not so much. The solenoid that engaged the roller will not work. Waiting for some test equipment to see what may be wrong. I was pretty anal about the caps when I replaced them, just ask Holger! So I don`t know what the deal is.
Teac X10R- RevoxA77MK2-OtariMX5050B2HD-Marantz1060-Marantz2220-Marantz2270-Marantz2325-Marantz Model23 Tuner-AkaiCSMO1A-Sansui SP-X9000-Bose Series2 901 Continental-AkaiSW155
Old 01-11-2017, 05:41 PM
Thanks for the replies, yes the dummy plug is installed and pretty tightly.
Deck is in pretty good shape and the seller said all was fine, but from the get go
The play, ff and play/record when pressed do nothing, does consistently rewind though. ugh.
Old 01-11-2017, 06:04 PM
I am assuming that you have not pulled any wires or pcb's out?
Seems weird that only rewind works. That means that your 27VDC supply is good.
Have you opened it up at all and made a visual check of the tape drive control pcb and all the relays that are plugged into it?
WWW.REVOX-R2R.COM
Old 01-11-2017, 06:57 PM
Banned
This is weird!
Yes, if any wires have been pulled, i would check if all are at the right place.
Old 01-11-2017, 08:24 PM
Tinman Tinman is offline
Make sure all the relays are still PLUGGED IN! Seen them fall out.
Revox B77 tape transport Revox Reel To Reel 72 09-24-2017 03:34 PM
Revox PR99 Transport issue Dcknuth Reel To Reel 4 12-18-2015 08:09 AM
Tascam 58 transport issue honkyjonk Reel To Reel 9 05-19-2015 09:24 AM
Sony CDP-C900 transport issue BillWojo Compact Disc 3 11-14-2014 07:09 PM
Revox PR-99 mk3 weird transport issue: need help Trigoner Reel To Reel 10 07-23-2014 01:25 PM
