Old 01-04-2017, 09:57 AM
crashgarrett's Avatar
crashgarrett crashgarrett is offline
door issue on Nakamichi
hello
i have never see that
two Nakamichi deck have the same problem
Dragon and ZX7
the door don't open completly
forced finish with the hand !!!
completly cleaning and greasing
help , please help ;)
Naks ZX7 with HCII , 700ZXE ; Nad 3155 ; Sony CDP-770 ; Aiwa XT-005 ; Bose 301
Old 01-04-2017, 10:05 AM
lucky's Avatar
lucky lucky is online now
Only see this issue if they aren't regular (daily) used.
www.luckyx02.de
Old 01-04-2017, 11:16 AM
perry's Avatar
perry perry is offline
Nakamichi Spoken Here
This typically happens when the platstic door guides reach the 120 degree change of direction in the aluminum slots. Typically a build up of old grease and plastic gum it up right there. But you said you cleaned and regreased. If it is actually stopping there, see if it works fine as long as you are holding down the eject lever. The slider that the eject lever actuates, is pulled from a slot in the arm that is attached to the spring. When you release the eject lever, that slider drags on the arm, and needs to be greased there as well.
Otherwise, it could be that the door guides have a groove worn in them, and need to be sanded smooth again.
Old 01-04-2017, 11:32 AM
yregelman yregelman is online now
I've seen this problem twice, both ended up having the same root cause: the metal brace part of cassette case assembly, the one that sits below the holder and forms part of the hinge was bent out of shape. It does not take much force to do it. Both decks looked undamaged from the outside. One was a Dragon, another one was ZX-9 I believe.. Both times it required disassembly. Once the brace is removed from the cassette case assembly, you can lay it on a flat surface, and see the amount of deformation. I used hands to apply some twisting force in the opposite direction in small successive increments, laying it on the flat table after each try to make sure I did not go too far. Sure enough a couple of times I went too far and had to apply the twist in the opposite direction.
Your issue may be different, but the only two times I saw this problem, this was the root cause.
Old 01-04-2017, 12:50 PM
zedex zedex is online now
Alleged serious tapehead
I had the same problem on one of my dragons. Cleaned the old grease,applied new grease, no change. Took it apart again, cleaned the new grease off, applied new grease again. Still sticking. I ended up sanding and buffing the plastic nubbs that ride in the groove and that seemed to work. I had the opposite problem on another dragon where the door would spring open too fast, and had to reduce the spring pressure on that one.
Old 01-04-2017, 02:29 PM
Nakmandan's Avatar
Nakmandan Nakmandan is offline
Todays Tom Sawyer
Agree with everything said thus far. It's a combination of guide pins, the aluminum plates and grease. If you hold the eject button in while the door is opening it should definitely move all the way on its own. I have seen some plates shimmed on one side or the other to make it better but I don't know if this was factory or not.
Old 01-05-2017, 11:46 AM
thanks for all your answers , i test this week-end
and tell you
Old 01-11-2017, 11:56 AM
thanks Perry
i do this :
Ok on ZX7 ; rest Dragon
Nakamichi Well Door Glue Trilobyte Cassette 2 10-16-2016 12:25 AM
Door latching issue on Denon DR-M20 Dave Matthews Cassette 4 04-26-2016 11:22 AM
Different Dragon Door Issue 83glt Cassette 9 02-26-2015 05:42 AM
Sony TC-WR901ES Door Issue recordslut Cassette 1 01-20-2012 10:29 AM
