  #21
Old 07-09-2016, 07:08 AM
Far too expensive. It is worth about $5.00
I just ordered 1.5uFd for $5.32 ea with free shipping.
Keep on looking. Amazon is not your friend. They sell a lot of defective junk and do not stand behind it. I do not buy anything off Amazon.
Try this one instead-
https://www.zoro.com/dayton-motor-ru...A&gclsrc=aw.ds
  #22
Old 07-09-2016, 11:33 AM
Why not just tack the new run cap in parallel with the old 60hz cap until you ascertain whether or not it cures the problem? If it does, I would re-stuff the can later on with both values, I like these units to look as well as work right.
FYI to the OP in case you aren't aware the third terminal on the cap Sam has linked is for mounting/mounting lug. If you had to, you could integrate it into the can mounts somehow but I wouldn't bother.
For me its easy to open the old can and restuff once I know that is the problem. 2 radial caps would fit just fine even though likely the 50hz cap will never be needed.
  #23
Old 07-09-2016, 08:05 PM
supersportsteve supersportsteve is offline
Problem solved, installed the new capacitor and its been playing for 3 hours straight with no dragging. I'm really amazed how good the sound quality is on this deck, thanks for everyone's help!
  #24
Old 11-29-2016, 04:16 AM
essence25 essence25 is offline
Which cap exactly did you install? Link?
  #25
Old 11-30-2016, 06:56 PM
Missed this back in July: Glad you got it all sorted!! YES!!! They do sound pretty darn 'good'_________
  #26
Old 11-30-2016, 08:48 PM
Hmm mine did the same thing. Did it twice and never again. The only difference it was plugged in an isobar. I was unable to replicate the reel slow down which occured about 20 minutes into playing music.
I do have a cap on order just in case. Its 2uF 250v smaller rectangular plastic package.
  #27
Old 11-30-2016, 10:50 PM
After all these years and in some cases these caps are becoming defective. I don't know why as most the time the caps are replaced with a film type just for a guess. Turns out the guess is right some of thee time.
I have 1.5uFd and 2uFd caps in stock now and 4.5uFd for the Otari decks.
Sony and some Otari decks are also having failures of this kind. it is all in a days work I guess. We had to replace quite a few caps in a Teac A1500 not too long ago and one of them did not allow the high speed to even work.
  #28
Old 01-10-2017, 08:27 AM
wcardone wcardone is offline
My A-3440 was doing the EXACT same thing. It would play fine for 15 or 20 minutes and then slow down and eventually stop. If I switched to STOP and then back to PLAY it would begin to transport the tape but immediately lose torque on the takeup allowing the tension arm to fall and stop the tape. The takeup solenoid would try to pull in and then give up.
it had a new capstan belt.
What corrected the problem was calibrating the machine torques. Buy some spring gages and that is about all you need other than a length of kite string.
Adjusting the torque on the takeup reel was a learning exercise. There are two screws and it is not immediately apparent which one to turn. They work together.
Wesley Cardone
Electrical Engineer, Fiat-Chrysler High Voltage Electrified Powertain
Strange low end problem on Teac 3340S johns82 Reel To Reel 12 03-20-2016 09:19 PM
teac 3340s tape lifter problem... towser Reel To Reel 20 05-21-2014 12:05 PM
Teac 3340s recording problem robertc2 Reel To Reel 2 11-22-2013 07:57 PM
Teac 3340s problem pluggedwood Reel To Reel 5 10-08-2013 07:58 AM
Teac 3340S Help Please !!! javelin Reel To Reel 4 09-16-2011 12:40 PM
