Old 03-25-2016, 10:49 AM
Linnovice Linnovice is offline
Studer A807 Spooling Motor Bearings
Hi all, I've had a problem develop on my Studer. In fast rewind there is a low drone and vibration coming from the left hand spooling motor (supply side). I've stripped out the motor and run it out of the machine and the noise and vibration are there. It's ok on overrun with no load but as soon as the power goes on the drone starts. Question. How difficult is it to change the bearings? Are they readily available?
Also, I noticed when I took the motor out of the chassis that there is a plastic toothed ring on the back of the motor. Mine has one tooth missing, would this effect performance?
Any advice and guidance would be gratefully received. M.
R2R=Studer A807 MkI & II, Revox PR99 MkII, Revox A77 MkIII 4 Track, A77 2 Track HS, A77 2 Track STD, Tascam 42B, Tascam 32-2B, Teac 3440 and 3340S
Small Scotch, Hearing aids and Happy Ears
Old 03-27-2016, 08:24 PM
I did mean any advice . . .
Old 03-27-2016, 11:24 PM
sunan sunan is offline
I don't know about the tooth. I got my A810 motors rebuilt by Athans corp. That included replacement of the 2 bearings. I am sure you can do it yourself. I don't know where you can get the bearings. Maybe you can ask George at Athans or maybe Tinman, Marc can help you
Old 03-28-2016, 01:01 AM
jan_stevns's Avatar
jan_stevns jan_stevns is offline
Tapedecks & Bernese mountain dogs ..that's life
Originally Posted by Linnovice View Post
.....Any advice and guidance would be gratefully received. M.
I'm rather sure it is tha SKF 608 2Z bearing they used.
In the UK i would try to call these people : https://www.bearing-king.co.uk/bearing/608-2z-skf/3555
Old 03-28-2016, 02:05 AM
337alant's Avatar
337alant 337alant is offline
Tapehead
I bought the energy efficient version from this seller as he is only 20 miles away from my home in the UK
I have used them in my Studer A810 and they fixed the same problem in my spooling motors
http://www.ebay.com/itm/141008775168...%3AMEBIDX%3AIT
Alan
Turntable - Garrard 401/Jelco 750L/Ortofon Kontrapunkt B, Pioneer PLC 590, SME 3009/2 , Ortofon Denon 103R - DIY Paradise Phono Stage.
R2R - Studer A810, Tascam BR20 , Otari MX55N, Revox PR99 Mk2, Revox A77, Teac 3440,
Digital HTPC / Young Dac, JRiver Media
Preamp - DIY B4 & 821, Power Amp's DIY Voyager Mono Block, Speakers Tannoy precision 6.4 / Wilmslow Kit Volt BM220.8 / Scanspeak D2905/9500
Old 03-28-2016, 11:32 AM
Tinman Tinman is online now
It takes 15 minutes to rebuild the spooling motors. Very straight forward. Just use high quality bearings or you will be doing it several times to find quiet one's.
You will need snap ring pliers.
As to a tooth missing on the tach wheel..... I'm not entirely sure. I never looked hard at mine. It's either an index spot to sense one full rotation, or a missing tooth.
Revox A77: Source for replacement reel motor bearings? dissonance Reel To Reel 26 03-22-2016 06:43 PM
Help with a Studer A807 Linnovice Reel To Reel 20 10-02-2015 08:28 AM
A Studer A807! Tinman Reel To Reel 15 10-16-2014 07:54 PM
Just Got A Studer A807... What Now? Good Vibes Reel To Reel 11 02-15-2014 03:58 PM
Studer A807 eshields Reel To Reel 5 12-06-2009 10:32 AM
