Go Back   Tapeheads Tape, Audio and Music Forums > General Audio Discussions > The Music Room
The Music Room Relax and set a spell in the Music Room. Talk about whatever strikes your fancy that relates to enjoying music, your audio system and components. Cigars and cognac optional.
Old 01-11-2018, 08:24 PM
sweatybetty sweatybetty is offline
ground wires
A few of my pieces have a ground lug on the back. Do they just hook together or to the ground on the 120v receptacle?
thanks all sb
Old 01-11-2018, 09:28 PM
john from seattle john from seattle is online now
I'd say, be wary of the various ground screws on the backs of various components, if you run them together, you may run into ground loops which can induce hum.
Best to try and isolate any component for ground issues and feed that ground back to a point source, the socket or some such instead of to another component.
Old 01-12-2018, 02:39 AM
keithatrochdale's Avatar
keithatrochdale keithatrochdale is offline
Hi
I always earth the amplifier and nothing else.
As said if you earth other equipment you risk ground loops and hum.
The other equipment is earthed from the amp through the screen of the connecting cables.
Nothing is foolproof to a sufficiently talented fool. Another of my hobbieshttp://www.astronomycentre.org.uk/ And of course; http://www.bmfa.org/
Akai 1721L, Akai 4000DS, A77, X-10, X-1000, 32, BR-20, BR-20T, MD-350, Ferrograph Logic 7, Kenwood DMF-3020, DMF-3090, Sony TC-399, DRM-555, DA-30, DN-C635, DN-T625, NAD 6155, NAD 5120, NAD 314, NAD AV 713, NAD T531, Otari MX-5050 BII 2, Phillips N3408, QUAD 33, 34, FM4, 303s, Sony MZ-G750 x 2
Old 01-12-2018, 03:59 AM
Ground lugs are wired with a thick wire type to a central point like a receiver or Mixer. The configuration is suppose to be a Star pattern.
In Radio stations a 4" copper strap material was often run around at the base of wall or behind studio furniture. This ground strap was tied into a pole that went 4-6 feet into the ground. Most consumer set ups do not need a ground cable but in cases where older electrical systems are had the grounds between wall outlets can be a lot and then present this problem.
Some equipment does not care as it uses two wire power that is not connected to the chassis until after the power is converted to DC.
Uher 4400Stereo, VU meter wires, where do they go Pine Marten Reel To Reel 5 06-10-2017 06:41 AM
headshell wires/leads question. kenwoodlvr Turntables and Vinyl 7 07-03-2015 08:19 PM
wires order pillz Turntables and Vinyl 6 05-30-2015 03:19 PM
Wires, Wires, and more Wires vinyldavid Picture Posts 9 01-09-2012 03:11 PM
Where to get the wires for my headshell? Warped Bezel Turntables and Vinyl 4 08-20-2010 02:18 PM
