Go Back   Tapeheads Tape, Audio and Music Forums > Tape, Taping and Tape Machines > Reel To Reel > Open Reel Tape Media
Open Reel Tape Media All aspects of tape itself; quality, characteristics, experiences, use and storage.
Old 01-11-2018, 11:09 AM
Thurman's Avatar
Thurman Thurman is offline
First Experience With LPR35
Recently received my first reel of LPR35. Question- Why is there so much tape on the reel? There is barely a 1/16 of an inch from outer edge of reel to tape media, thus the tape is always wanting to spool off the reel when mounting and threading; a bit of a hassle. Did I receive an overly loaded reel, or is this normal for LPR35? As far as recording with it on my TEAC A-3340, it yielded good results, but not as good as vintage Maxell-UD. Can't take certain hard rock passages and the soundstage seems flat; lacks depth and sustain if you know what I mean. I also tried LPR90, but my deck does not seem to like it at its present setup and calibration. Got a lot of tape hiss in soft passages of music. It does seem to take harder inputs better than 35, as expected. Wish there was something between 35 and 90, as I don't want to have to recalibrate. Wishful thinking on my part.
Thurman
Old 01-11-2018, 05:37 PM
johns82's Avatar
johns82 johns82 is offline
The calibration is most likely off. If the deck likes UD then it should be close.
Remember I am no fan of LPR 35. The hiss is a indicator of everything being out of whack but I have noticed LPR 35 is hissy on some decks.
Try the Capture tape, I would think that should work out as it's more of the consumer type tape.
Old 01-11-2018, 06:39 PM
Thurman's Avatar
John,
Who is the go to dealer for Capture, and what specific tape should I buy?
Thurman
Old 01-11-2018, 06:42 PM
XJ6listener's Avatar
XJ6listener XJ6listener is offline
Gotta agree with johns82 regarding cal. I'm using LPR35 for everything, no hiss / no nothing / just spacious detail w/plenty of headroom.....shrug
John
I am thinking about changing into the 900 series though just to go thicker but LPR is serving me well.
John
Old 01-11-2018, 07:19 PM
Like some people in the past that questioned the quality of LPR35, there is no better tape than that tape and if UD sound better the deck is not set up properly for the LPR35. I have adjusted many decks to LPR35 and it has done a wonderful job on any deck I used it on. Maxell UD is a long past formula maybe 40 years old- I put that tape in the brake test category.
The XL I is still a good tape but LPR35 beats it.
Old 01-11-2018, 09:26 PM
Splicit sells Capture tape, in 7" reels, it's 1200 Ft (equivalent to 60 Min in Cassette land), or 1800Ft, which is the equiv to 90 minutes, but that's for 7.5ips though. Double that for 3.75ips and if your deck can do 15ips (the 3340 can't do that fast), half that, just to give you a reference.
It's normal for 1800-3600 Ft length tapes on 7" reels to get quite close to the edge, but there again to get 3600Ft on a 7" reel, it has to be half a mil, not the full mil of 1800Ft, or 1.5mil for 1200Ft, just to give a reference.
As far as bias/calibration is concerned, your deck may be off, not unusual if not restored electrically and re-calibrated to a specific tape.
Old 01-11-2018, 10:43 PM
Gussers's Avatar
Gussers Gussers is offline
Originally Posted by Thurman View Post
John,
Thurman
Splicit, Capture 930
Revox A77 MK 1, Akai GX-230D, Nakamichi 480, Akai GX-M50
Old 01-12-2018, 12:49 AM
YOUR 3340 may no go 15ips, but mine does... spec sheet here also indicates as much.
http://www.thevintageknob.org/teac-A-3340S.html
Old 01-12-2018, 03:19 AM
RWise RWise is offline
My 3340 does 15 ips, one can look at the capstan shaft, if it's (larger) ceramic it runs 7.5/15 ips
Notice: All unattended children will be given a Dr pepper, 4 Oreo cookies, a bag of M&Ms, and a puppy!
Old 01-12-2018, 03:54 AM
All A3340S or 3340 deck went 7.5 IPS and 15 IPS. The deck that went slower were using the same transport but a different capstan shaft and that would be the A3300S or SX but there were versions of A3300SX that went 15 IPS but may have been 2 track. A3300SX-2T is what they were called.
The A2340S or SX or SR were the ones that always did the slower speeds
Old 01-12-2018, 06:04 AM
johns82's Avatar
Yep go to Splice it and try a reel of 930. Get a seven inch reel just to find out IF YOU LIKE IT!
Old 01-12-2018, 07:50 AM
OK, so the 3340 can do 15ips, I stand corrected.
Old 01-12-2018, 11:18 AM
Thurman's Avatar
Thanks all. I have ordered a 7" reel of Capture 930 to give it a try.
And yes, my 3340 does 15 ips too, but don't use it all that much, as it performs incredibly well at 7.5 using half the amount of tape.
Thurman
Old 01-12-2018, 04:44 PM
johns82's Avatar
15 IPS is great for signal to noise as the higher speeds need less EQ boost. Less boost less hiss. Also as speed increases chances for dropouts are reduced as the time of travel over the heads for a bad section of tape is reduced.
Mostly 15 IPS on home recordings is not needed. Heck with a lot of work and dbx type II I have gotten great results at 3 3/4 using lowered record levels.
Old 01-12-2018, 07:04 PM
I just finished a modified record EQ deck in a Teac A6300. The deck rolled off fast after 15 KHz when I started. When I finished using LPR35 tape the response at 7.5 IPS was 22Hz to 24KHz inside of plus or minus 2dB and at 0 Vu referenced to 200 nWb/M flux density. Just another example that that tape has some good stuff in it.
Old 01-12-2018, 10:53 PM
I have to agree that LPR35 is excellent. Perhaps you got a bad reel? It is certainly one of the brightest tapes out there. Capture will be less bright but all things being equal Capture is plenty bright.
Old 01-13-2018, 03:12 AM
johns82's Avatar
Yes I did a A 6300 for a customer using LPR 35 and at 200 nWb 0VU it went out to -3 dB at 26 kHz +/- 2 dB at 24kHz as well. but of course I got this using venerable Scotch 207 on my A 6300.
But then again I got my Akai GX 270 D with a modified/adjustable play/record EQ to go out flat past 22 kHz with oldy timey Scotch 203.
All the discussion of "how good" a tape is is based on "how is the deck calibrated". If somone has not the calibration equipment then discussing how the tape should sound is a non sequitur.
Let's see if the OP's deck works with the next tape. I would assume the reason for so many different tape formulas years ago was that someone could find a tape they liked, not that they had to calibrate to.
Old 01-13-2018, 09:25 AM
Thurman's Avatar
While waiting for the reel of Capture to be delivered, I decided to retry LPR90 using different source material (Pink Floyd's Animals) and was completely blown away. I guess on my previous recording with 90 I was using source material that already had inherent tape hiss when it went to CD. If LPR90 performs this good most of the time, I will be very happy. Anxious to see how the Capture will compare.
Thurman
Old 01-13-2018, 09:44 AM
Rat44's Avatar
Rat44 Rat44 is offline
Site Supporter
Its a very good tape thats affordable.
Use it with a RT 707 and Teac X1000.
Both my machines have been calibrated to it when recently serviced.
Pioneer SX1250 ADS L 810 Teac X1000R Nak BX300
The two loudest sounds in the world are a "CLICK" when you expect a "BANG" and a "BANG when you expect a "CLICK"
New RMG LPR35 tapes platesamler Open Reel Tape Media 3 10-14-2016 08:26 AM
LPR35 & 911 oldaudioscho Scores, Woulda-Coulda-Shoulda and Tall Tales 0 12-23-2012 02:51 PM
Just loaded some LPR35 Doug_Olitsky Open Reel Tape Media 17 12-14-2011 06:58 PM
LPR35: Is slower really better? Class A Clown Reel To Reel 17 08-18-2011 08:58 PM
Who wants to buy RMGI LPR35 in the UK? crome Reel To Reel 15 01-07-2011 04:33 AM
