Go Back   Tapeheads Tape, Audio and Music Forums > Tape, Taping and Tape Machines > Reel To Reel
Reel To Reel All discussions pertaining to reel to reel decks. These include general usage, recording, playback, and service questions. For subjects related to tape itself, see the Open Reel subforum under this one. Obscure service subjects that don't quite fit go in the Help and Do It Yourself subforum.
  #61
Old 09-08-2012, 02:48 PM
tonysal123's Avatar
tonysal123 tonysal123 is offline
Secret Agent Man
Does anyone remember the TV series Danger Man/ Secret Agent Man' miniature reel-to-reel tape recorder hidden inside the head of an electric shaver?
  #62
Old 10-16-2012, 11:03 AM
DaveInVA's Avatar
DaveInVA DaveInVA is offline
audiophool deluxe
A Lloyd's that is very similar to the TDK unit I posted a while back. Still works after a good clean and lube. No model number on it anywhere not even inside. No makers mark inside either. Also the same mechanism as the Freeman's I have. 2 speed capstan drive and no belts. Heavy as a brick.
Dave
  #63
Old 10-16-2012, 11:09 AM
DaveInVA's Avatar
audiophool deluxe
And here is an AFCO Executive just like the one Southcoast posted a while back. I knew I had one of these somewhere. It's missing its head cover but it does still work.
Dave
  #64
Old 11-06-2012, 11:40 AM
DaveInVA's Avatar
audiophool deluxe
Here is the same model used in some of the early Mission Improbable's. Its a Sanyo Craig 401 and its pretty tiny. All metal construction unlike the later Craig rim drive models that were all plastic like one of the others I posted. Its a single motor with rheostat adjustable speed. The motor was seized and I had to adjust the cradle that tilts the motor shaft into the rims as the rubber has probably shrunk some. Uses 4 "AA" batteries.
Dave
  #65
Old 11-16-2012, 10:33 AM
DaveInVA's Avatar
audiophool deluxe
This was a $12 rubbage sale find years ago. A Minifon Attache cartridge tape recorder. This replaced the model P55 wire recorder and looks much the same. Very well made and even has a tape counter (still works). Runs off a (now dead) original 6-8v battery. Will also run off an ac adapter. I need to find more of the accessories for it as it has no built in squeaker and has non standard DIN style plug-ins.
Dave
  #66
Old 11-16-2012, 01:33 PM
southcoast68's Avatar
southcoast68 southcoast68 is offline
Man, its amazing how many manufacturers used the same transport in their recorders. So far, I have spotted the same transport that is in the AFCO in machines marketed by; Freeman, Olympus, Lloyds, and Fanon-Masco. The Minifone is cute too. Someday, I'd like to find one of these in good shape, the Minico Junior.
  #67
Old 11-16-2012, 01:43 PM
DaveInVA's Avatar
audiophool deluxe
That Minico looks like the same mechanism as the Craig 401 I posted...
Dave
  #68
Old 11-25-2012, 12:34 PM
DaveInVA's Avatar
audiophool deluxe
This is a cute little Geloso 256/60U tube recorder from the late 50's. Runs only at 1.875 ips. It uses both miniature and snausage tubes. I kept this one in case I find another to try and make a good one from 2. This one is missing its tape counter pointer (lower left dial). The electronics work even the DM71 sausage Tragic Eye tube. The belt is to stretched for FF to work. Unfortunately these have a design flaw. The rubber idler is always engaged to the small motor shaft so if these sit unused for any length of time the idler gets a deep dent in it. Not really worth fixing, just for parts for now.
Dave
  #69
Old 12-01-2012, 02:27 PM
DaveInVA's Avatar
audiophool deluxe
Another one from the collection. A Hitachi TRQ-370 2 speed capstan drive tiny recorder with real leather case and original box. With microphone and its leather case, leather strap, Hitachi logo'd polishing cloth and inspection tag. Some parts inside have 1960 date codes. This one actually has an unique mechanism and isn't the same as the Freeman's, AFCO's etc. Works perfect after a good clean and lube.
Dave
  #70
Old 12-02-2012, 08:30 AM
Listens2tubes's Avatar
Listens2tubes Listens2tubes is offline
Supporter of Reel Analog-resistance is futile!
More amazing mini decks than any man should have and still counting. And most even work.
(3) Otari MX-5050Bll-2 - main deck with MTR metal "smoothie" heads, Ampex A-122 & F-44, Teac A-4010S & A-4070, A-6010 GLS, Revox A77 Mk II, Heath A-16 (Magnecord 1020) __
  #71
Old 03-13-2013, 12:30 PM
DaveInVA's Avatar
audiophool deluxe
One of the first transistorized portable tape recorders made from the mid 50's and it was even made in the US instead of Japan like most of the 60's units. This is a Pentron "Transitape" portable that runs on 8 "AA" cells at 1.875 and 3.75 ips. Was also sold under the "Steelman" name. Built like a tank and weighs nearly as much as a tank also. All early Germanium transistors with 2 digit numbers (ie 2N34 etc). No cicuit board, all hand wired. Transistors are even in sockets but glued in so they don't fall out. Uses a real erase head instead of a permanent maggot and is capstan drive with a decent size flywheel. The original belts are still in usable shape but I had to take the motor apart because the brushes were not being held tight enough to the commutator so a little creative bending of the brush springs was all that was needed along with a small drop of oil on each bearing. Also did a general clean and lube and it works fine now. This has the fastest FF and REW I've seen yet on a 3" portable.
Dave
"Capitalization is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse.
Grammar: The difference between knowing your shit and knowing you're shit.
  #72
Old 03-17-2013, 09:38 AM
DaveInVA's Avatar
audiophool deluxe
There is one on FleaBay right now (no relation to seller):
http://www.ebay.com/itm/Minico-Junio...item3a7f77c49a
Dave
  #73
Old 03-17-2013, 01:07 PM
Thanks for the heads-up, but for $199, these folks are smoking some real good stuff. I would have been tempted to bite at $50.
Edit: ok, I just noticed who has it up for sale, Zipporeel. This guy/gal had a couple of YT videos of their amazing collection of spy recorders (one experimental recorder inside of a Zippo lighter). I can't find the videos anymore, they may have been taken down. But at least this Minico was well taken care of in a collection, still too rich for my blood though.
Cheers
  #74
Old 03-17-2013, 01:10 PM
DaveInVA's Avatar
audiophool deluxe
Cheers
I bet the price will come down after they run it a couple times with no interest.
Dave
  #75
Old 03-17-2013, 01:22 PM
I added to my post while you responded. This machine is from a massive collection of spy reel machines.
  #76
Old 03-27-2013, 11:01 AM
DaveInVA's Avatar
audiophool deluxe
This is a Star-lite Pocket Mate from the 60's. It uses the same mechanism as the Tinico that Twinimage posted awhile back. This unit is a little bigger because unlike the Tinico it has a built in amp and squeaker. It uses a rim drive system with the same non-standard tape spools as the Tinico. I put a "C" cell next to it in one of the pics to give a scale to its smallness. This one the motor was sleazed as was one of the spool tables. All lubed and cleaned now. Still has its tiny lapel mic. This one uses a real erase head instead of a permanent maggot.
Dave
  #77
Old 03-27-2013, 01:54 PM
Old Busted Hotness's Avatar
Old Busted Hotness Old Busted Hotness is offline
Am I doing this right?
Oh, that? I always carry a carton of smokes with me, in case I run out. Please continue, speak up a little, though.
Open-Reel: Pioneer RT-1020L, RT-701, TASCAM 34 Cassette: Yamaha KX-630, Denon DR-330
All she knew about music was that it came out of funny looking machines, and you didn't want to marry the people who made it.
  #78
Old 03-27-2013, 02:30 PM
DaveInVA's Avatar
audiophool deluxe
Its even smaller than that. With the leather case its 7.75 X 1.75 X 2.75".
Dave
  #79
Old 03-28-2013, 09:52 AM
The ultimate in "Bond" equipment at the time eh?
  #80
Old 05-10-2013, 02:17 PM
DaveInVA's Avatar
audiophool deluxe
This isn't really miniature but its an interesting unit. Its an American Concertone Cosmopolitan 400. This was made in 1963 after Concertone was absorbed by TEAC in the early 60's. It is capstan drive with 2 speeds, up to 5" reels and has a built in AM Radio. Its very well made and mostly metal. Instead of having a leather case to slip into the outer housing is leather covered metal. Has a counter and metal screw down reel holders. 2 heads. Uses metal slinky belts that never rot or deform. About the same size and weight as a UHER 4000 series. I had 2 of these in bad shape and got bored today and made one good one from the parts from both. The last 2 pics are from 2 Man From Uncle episodes that used this model. The last pic is from a 1963 Brochure.
Dave
Roberts 778x (Akai X-1800SD) Reel to Reel. Help needed to repair 8-track, please :) purpleomega Reel To Reel 17 09-22-2017 07:55 PM
Braun TG-1000 Reel to Reel player - one dead channel worth the hassle? tbllau Reel To Reel 10 07-18-2015 08:05 AM
some small reel to reel recorders/players audioribbon Reel To Reel 7 03-12-2012 09:45 PM
